Help needed! Diamond/ Compak k6
  • Help needed! Diamond/ Compak k6
    I scored this diamond k6 grinder during the week for $100 which I thought was a bargain ! I don’t know a heap about them but I’ve read up as much as I could find on these forums and reckon it was a good score .
    I wanna fix it up so I’m looking for anyone who knows about these grinders.
    The doser doesn’t turn but other than that it seems to be pretty good.
    Does anyone have any info on them, how to get the doser going again , maybe a detailed schematic or something?
    snd where I could get parts from ?
          Sorry bout the sideways pics, I dunno how to get the upright
            As you can see the doser is pretty filthy!!!
            what can I use to clean it up? Are there any solvents that are good for coffee oils/ residue ? Anything I should avoid? I don’t wanna scratch it up so don’t know if I should use a scourer or steel wool
              This exploded view from the documentation secion under this section, grinders, might help
              https://coffeesnobs.com.au/forum/equ...-exploded-view
                Perfect! That’s exactly what I was looking for
                thanks 338
                  If that's what the doser looks like, I would also recommend a thorough disassembly and clean of the burr chamber and chute!
                    Lol yeah I plan on pulling the whole thing apart and giving it a proper clean
                      Do you know what I can use to clean the residue I off the doser ?
                        Cafetto espresso clean is designed to break down coffee residue. You should have something to be cleaning your machine with (assuming you have a machine). Use a teaspoon in about 100ml or so of boiling water, then once it cools a little soak some up in a cloth and wipe it with that. If it's really built up you can remove the bulk of it by mechanical means before attacking with the chemical. I would suggest a wooden paddlepop stick and/or a bamboo skewer.
                          Okay great
                          I have the cafetto tablets so I’ll dissolve one of them but I think I’m definitely gonna have to use some elbow grease , thanks for paddle pop stick suggestion, I reckon that’ll work well
                            A friend with a K6 found his grind adjustment seized due to lack of use, and living on the waterfront - a tiny amount of corrosion led to a difficult job of getting it moving again. It is definitely a good grinder though, and well worth cleaning up!
                            Good luck with it.
