Good Morning CSs,
I had a play with the Delonghi KG59 from work last night and was hoping someone could confirm the little mod Im going to do is not going to kill this little machine.
Basicly the hopper has the Stator Burr attached to it by 3 small screws, Im thinking that if I remove the Stator Burr and place a washer or spacer of some sort under the Burr at each screw this will bring the Stator Burr closer to the Rotator Burr.
By then starting with the hopper set at the most course grind and slowly turn it using the 10 grind settings till I get a finer grind.
Dose this sound like it would work...? It sounds to easy to me....
Any thoughts...?
Cheers Grug
Any thoughts...?
Cheers Grug
) and you will probably find you can move it from side to side and up and down as well (we are only talking small amounts.... but with grinding for espresso..... any amount is too much!)
