Baratza Sette 270Wi shims
  • Galeforce
    I got my 270wi a few weeks ago and installed one of the shims straight away before using it. The reason was simply that I'd read here and saw in some YT videos that most people had to eventually add at least 1 shim for espresso grinding. Now, I'm on macro settings 6 and 7 depending on the bean.
  • hedonist222
    Try emailing Baratza.
    Going to 1 seems extreme in my opinion.
  • RainerLink
    Yes, actually I cleaned it after being forced to adjust to 1 - and it stayed the same.
  • hedonist222
    Originally posted by RainerLink View Post
    I'm grinding at 1 right now after a year at 3. Needed adjustment only when trying out a different coffee. Have cleaned the machine with a brush recently. I grind about 40 grams daily.
    Are you positive you've screwed the cone back on fully?
  • robusto
    RainerLink, The shim is 0.3mm thick, the ID is approx 12.5mm, OD approx 29mm. Then you have those two slots, about 5.4mm long by 5mm wide
  • RainerLink
  • hedonist222
    hedonist222 At the very moment it is fine enough. I've been using the Sette for 1,5 years now and just a few weeks ago I had it at 3 - so I guess I will have to adjust the grinder in a while at least. It was stable for about a year and actually I was very surprised to be forced to move it to 1...
    Are you at 3 or 1 now?
    Have you tried cleaning out the machine?
    I don't recall going down very drastically in the years I owned it.
    Maybe a notch or two.
    From 5-6 to 3-4 after a few months.
    Then no more changes.
    I grind about 30 grams a day everyday.
  • RainerLink
  • hedonist222
    Hi, does anybody know if the original Baratza-Shims are required for additional adjustment (which I have lost unfortunately...) - or who has experience in using conventional hardware. Which did you use (external and internal diameters please)?
    What are you grinding at now?
    If you're grinding at 1A and its still not fine enough, then yes you would need a shim.
    Adding a shim at your current 1A, will be the equivalent of 5A or 6A.
    So you could then go down to 5A or 4A.
  • RainerLink
  • robusto
    The shim/s of course fit tightly between the burr and carrier and can't move independently of the burr. In any case, the centre cone burr where the shim is placed, is stationary, and it's the outer burr --which has no shims--which rotates.
  • hedonist222
    Originally posted by hedonist222 View Post
    In your case robusto, the shim serves no purpose - because without it you'd be grinding at 3-4
    Baratza says each shim adds 5-6 levels
    Its not harming anything - well other than maybe perhaps reducing centrifugal force - but that would be negligible
    While I'm not a rotating machinery engineer, I understand that unattached-mass will affect centrifugal efficiency.
    But like I said earlier, negligible if shim is securely tightened to shaft.
    commented on 's reply
    How would the addition or removal of a shim contribute to this exactly?
  • hedonist222
  • robusto
    Is that a 270 or 270W? My 270wi came with no shims installed, but 2 as extras in case needed. For some reason--I can't remember why--a year or so later I put in one shim. Espressos are about 9 macro.
