Mazzer Mini - stiff dosing lever help
  • Mazzer Mini - stiff dosing lever help
    Hi There,
    I’ve noticed my Mazzer Mini (several years old now) has become quite tight/stiff/resistant when pulling the dosing lever And I’m assuming it just needs lubricating. The manual that came with it doesn’t go into detail on maintenance and would love some advice on the best lubricant/how to please. Appreciated!
    Pull the doser apart and give it a thorough clean pbags (pretty simple device) probably all gummed up with coffee grounds after years of use, no lube should be necessary, in fact oil or grease will just make a mess when it mixes with coffee grounds.?
      Great thank you for the tip! I will give it a go
      appreciate the tip.
