Mazzer Auberins Mod - layout choices and button spec
  • Mazzer Auberins Mod - layout choices and button spec
    I'm midway through a 1999 Mazzer Super-jolly restomod project. So far I've I've done the "resto" part, and am making good progress on the mods!
    I've swapped the doser for an OEM funnel, and have mocked-up the Auberins timer in an external box to check it all works and I've got the wiring right (I have!).
    I've been um-ing and ah-ing about layout of the timer parts in the mazzer body:
    Having the timer on the left side (as you look at it) makes the most sense - replacing the big mains cable grommet hole (mains cable re-routed out of the bottom-plate).
    However, this didn't leave anywhere obvious for the 3 timer push-buttons. I've finally decided to have two of them (single and double) in the bottom two corners of the motor cover plate. Really pleased with this - they look great there, and are easy to access:
    The third/final button is the "grind on demand" momentary button. It's temporarily sitting in the cable grommit hole in the above photo - but the timer is going there. What I'd like to do is have this button replace the on/off indicator lamp on the front of the machine - again, should look pretty neat, and would be easy to get to.
    This is where I need some help.....
    Ideally I need a momentary, Normally off push button, which is illuminated via mains voltage. I'm really struggling to find one of these - they all seem to be either illuminated by 12v, or enormous ugly expensive things.
    I'm sure I've seen somebody do exactly this (it was even green!) - but for the life of me I can't find it.
    Does what I'm looking for even exist? Can anyone point me in the right direction?
    Nice work!
    Some possibilities for the illuminated button, RS Components part numbers:
    1758940
    1115826 (latching though not momentary)
    1115823
      Thanks ninja...... that last one looks spot-on, much appreciated. Will get that order and post some pictures once it’s fitted!
        please do Batfink !
