Macap M2M Chute removal?
  • Macap M2M Chute removal?
    Anyone know how to remove the chute on the Macap M2M? I removed the top burr carrier and seen there is an Allen key at the top holding it in, but after removing this bolt I still couldn't take the chute off. Just want to give it a good clean, thanks.
    I don't know how to remove the chute, but would this help? https://www.espressotec.com/macap-m2-parts-diagram.html
      No need to. Bottle brush or remove the lower burr should you feel so inclined- and then brush out.
        There is another bolt that can be accessed by taking the base off the bottom of the grinder. Make sure to do this with the grinder unplugged as there are exposed electronics in there. Good to give it a clean out too as I often found a small amount of grounds make it into there over time.
        • yldlj
          yldlj commented
          Editing a comment
          Thanks, next time I give it a clean I will look for this.
