Question re la cimbali junior grinder dials
  • Question re la cimbali junior grinder dials
    [smiley=2vrolijk_08.gif] Picked up my 2nd hand la cimbali junior grinder today......they even threw in a hopper full of my favourite beans ;D
    The previous owner said not to adjust the dial inside where grounds are.....but what is the dial on the outside front for left/below hopper??
    thanks
    Re: Question re la cimbali junior grinder dials
    The dial on the inside of the doser is for when you use the 3 click method. I.e. grind a doser full of espresso until each one of the chambers is filled. The dial will then allow you to adjust how much coffee is deposited per click of the handle. You can leave that alone because I assume you will be grinding on demand.
    The other dial you are referring to is a worm gear driven adjustment for the grinder. Allows infinite adjustment of the grinder. Mind you, to go from espresso grind to plunger is painstakingly slow.
    Good luck.
