Purchasing grinders overseas
  • Purchasing grinders overseas
    Wanting opinions on purchasing a grinder overseas, as the cost of a unit + shipping is significantly less than purchasing in AUS. Also are there any complications with power plug issues? I'm mainly looking at 2 or 3 stores in Europe so I know their voltage is the same as what we use
    Just would like opinions on this subject
    Thankyou!
    Hi
    I am not a sparky , but I believe there is a standard AS/NZS 3820 and if your import doesn't meet it then if worse case happens, you could be a) uninsured b) unlawful.
    So although voltages may be similar there are hoops to jump through ( probably for a reason). I am pretty sure if you look at threads about the Behmor roaster and Australian compliance, there is more to it than that.
    So for me caution urged, and as a relatively major appliance it is good to know there is some warranty and support locally.
    • FilthySudo
      FilthySudo commented
      Editing a comment
      Yep that's fair points you make! I was looking at importing a eureka and the 900$ vs aus 1300$ price was a significant difference. Obviously you just have weigh up if it's worth the peace of mind! I want peace of mind, but if I am covered for having an EU grinder then I'll be happy to go that route. I just can't seem to find much online in regards to this topic
    • FNQ
      FNQ commented
      Editing a comment
      Just a note. The standard quoted may not be the correct one. I don't want to mislead anyone , so please do your own research as well.
    If it doesn't have the RCM (tick in a circle in a triangle) then you're not covered by your insurance company.
    • FilthySudo
      Editing a comment
      Where does one see if it has this? Should it be in the description or specs? Or on the box or unit?
    • 338
      338 commented
      Editing a comment
      Filthy it has to be on the device itself. In most cases it is on the main sticker
    • FilthySudo
      Editing a comment
      Ahh okay! So how would you know if a product from Europe would have this? I'm assuming it wouldnt? Mainly looking at 30.coffee and espressocoffeeshop
    I have two Eureka Mignon grinders - one purchased locally from official importer and another one from espressocoffeeshop.
    The only difference is the plug. The stickers are almost identical (different models but none of them got any RCM ticks).
    If I hide the plug you will never identify which one was purchased locally and which one was imported.
      An article about what to do if your appliance /gadget wiring doesn't have an RCM mark is here
      Interesting points from the article (( from my gleaning )
      THE CE mark is not recognised for Australian regulation purposes.
      The requirement about RCM approval applies to importers as well as retailers
        For the sake of $400.00, buy locally. That way you will have local warranty backup if needed, as well as local compliance.
        Save for a few weeks more if needed.
        • FilthySudo
          Editing a comment
          I might just wait till they are stocking the units rather than a pre-order so I can see some more reviews
