Hi,
I've been off the forum for some time but still chasing my hobby of coffee
I'm after a single dose grinder that is equal to or better than my HG-One for espresso (90%), with the odd use for plunger (5%) or pour over (5%)
I own an HG-One and due to nerve injuries that have ended my working capacity I also incidentally have issues grinding my coffee some days (both major life events!).
I'm unsure:
A. What the HG-One is worth (It's in pristine condition)
B. What choices are good ones in the current market as good or better grind than HG-One for my grind requirements described above?
I was thinking Niche Zero until I read of some issues as an Australian Market which make the company seem a risk.
Eureka Oro Mignon?
Another I saw that has some sort of bellow on top (can't recall the name but it was mentioned a few times on the forum here as a Niche Zero Alternate)
I found this one online but I'm not familiar with its development and rep: Lagom P64 Flat Burr Grinder- estimated late Feb 2022 dispatch — OPTION-O
My criteria are:
1. zero retention (including no major static issues that must be worked around)
2. single dose grinding (up to about 20g most days is what I use for a double)
3. reliable
4. low noise
5. able to be adjusted between grind settings relatively easily (for different beans for example - or to do a cold brew in summer and switch back to espresso).
I'd appreciate advice or input - especially from owners
.I'm after a single dose grinder that is equal to or better than my HG-One for espresso (90%), with the odd use for plunger (5%) or pour over (5%)
I'm unsure:
Eureka Oro Mignon?
My criteria are:
3. reliable
4. low noise
