Well she is finally here. Ordered June 30 2021. Tracking number assigned March 4. Arrived today in a box that was crushed on top, presumably from the weight of other packages. But full credit to DHL, it showed now signs of having been dropped.
Packaging was better than it has been in the past, based on posts in less prestigious forums such as HB, but still not as good as most other manufacturers who custom cut foam and double box.
The Livi arrived in a large box and was wrapped in a combination of thick wrapping paper, plastic bubbles with air and Styrofoam balls. The packaging did the job of protecting the machine but I suspect only because it was treated with some respect by DHL handlers to whom I am eternally grateful.
Tomorrow I'm removing the Italmill 83mm conical burrs and replacing them with Mazzer Robur burrs.
Then I'll be seasoning the burrs and after that I'll put her through her paces and let you know what I think.
I bought the grinder because I think it's beautiful and its workflow looks good enough and it is engineered to high quality, German, hand crafted standards. And if you think it looks good in the pics, it's even more gorgeous close up.
I intend to pair it with the Strietman CT2 for medium to dark espresso.
