Eureka ATOM 75E Specialist, being replaced under warranty
  • Eureka ATOM 75E Specialist, being replaced under warranty
    Hi All
    This machine was bought new in Dec 2021, and arrived mid Jan 2022. We suffered with issues to the point where it wouldnt grind, we grind fine as required by the Single Origin Paradox blend we like to drink and it seems this grinder would constantly clog despite having the new chute etc. The motor ended up going and after lots of hassle with the store, they have agreed to replace it with a new one some 6months later
    Once bitten, twice shy. I'm now thinking of avoiding this grinder totally
    Any suggestions as to what to replace it with so we dont suffer the same fate? I dont want to be declogging a grinder every 2 days - this to me is simply a design fault.
    Thoughts? Thanks!
    Sam Remo have the allgrounds with tool less entry to the burr chamber.
    what sort of drinks are you making and how often? What machine do you have?
      All milk based, I will pull 5-6 doubles per day so tiny volume
      I have the Profitec Pro 700 V2
        I have the Profitec 600 and Eureka Specialita with a single dose bellows. We make 2-4 milk based drinks a day and very happy with the set up. I was chatting to someone who had a couple Eureka grinders including the Mignon and Atom 75. I was thinking of upgrading to the Atom. They basically said there wasn’t much in it just Atom was faster so I’ll probably stick with what I have. Works very well for single dosing almost zero retention and very little waste.
        https://www.etsy.com/nz/listing/1096..._1&crt=1&sts=1
        there are plenty of reviews on the Specialita. It’s very easy to clean out and stepless just like the atom. Nice small for print. The XL version has 65mm burrs. That is as large as it goes.
          Lately many Eureka machines have been defective.
          By many I know of 3 models that are defective and Eureka have admitted this.
          It appears your spout is clogging up. All the grinds are being held in the chamber and thus taxing the motor.
          I picked up a Ceado e37sd.
          • coffeemachine
            coffeemachine commented
            Editing a comment
            Do you know which model Eureka have said have issues? Would be interesting to know.
          The Helios series.
          And the model that came after the Helios. Not the ORO.
          • coffeemachine
            Editing a comment
            Interesting. What are the issues with the Helios?
            Is the other one the XL by chance?
          • hedonist222
            hedonist222 commented
            Editing a comment
            The clump crusher was made of tin. It was so flimsy that it bent upwards.
            So you had no clump crusher.
            Ground coffee was literally coming out the chute in cubes.
            I really cannot remember the latest model.
            Doesn't matter.
            I won't purchase a Eureka for at least another 5 years.
            By then, who knows if I'll need another grinder and if I'll opt for another brand.
            What bothered be about eureka is that they admitted the model were faulty but never really followed up with me.
            In fact they said the fix would be soon, a week or two. But that turned into about two months.
            That's when I returned my Helios for a refund and wrote off eureka.
            Mistakes happen.
            It's how you handle it that matters the most.
          Agree.
          If the machine cannot do without cleaning for a week in my view its defective. You shouldnt have to declog a machine every week especially seeing as we arent even near the finish setting. Thats only 40 odd coffees, usually not even.
          In any case, they gave me another Atom 75 yesterday as they said its really the best option . If this one fails, it will be onto something else.
            Yes this should not be happening. Hope this unit is better. Nothing worse than buying new kit and not having it deliver.
            You could always try this sort of bellows as the Atom is more for on demand. Will clear out the grinds in the chamber and chute.
            https://www.singledosebrew.com/shop/...tention-hopper
              I cannot recommend NOT using bellows on an Atom strongly enough. They're not set up for it.
              • San
                San commented
                Editing a comment
                I use Atom 75 for a single dosing for months and don't have such a messy problem: the chamber clean as it was brand new, however I don't use bellows but a gentle tap while running clears any remaining grinds. Just make sure that all seals sit tide and add shim if required.
                When I use it with a hopper, 0.25sec clears old grinds, no clogs whatsoever.
                I've noticed that very dark, oily, roasts tend to clog any grinder more than light & medium roasts.
              • lancruiser
                lancruiser commented
                Editing a comment
                The Eureka blow up system was available before the release of the Atom 75. Eureka also states that the 75 is compatible with the blow up system. The rubber gasket from the opening on top extends to the grind chamber and there is also rubber gasket connecting the chute to the grind chamber. It does looked like Eureka designed the 75 for the blow up system. I think there is a lot more to the story that comes with those pictures. Perhaps the one or more of the gaskets were not in place?
              • coffeemachine
                Editing a comment
                https://www.youtube.com/watch?v=be2t2UqkO-o
              Surely that points to a fault in grinder design. Bellows don't pressurise the air greatly. If there is that amount of grinds "leakage" in the grind path with bellows, won't there still be significant amounts without bellows, maybe over a longer time frame? Maybe this is a one-off issue with a particular grinder? Although from the report of blockages as well it seems that model at least has issues
              • level3ninja
                level3ninja commented
                Editing a comment
                The whole point is that they pressurise the air enough to move ground coffee. I'd say it's just that bellows weren't taken into account when they designed it. Haven't heard of significant build up without bellows.
              • coffeemachine
                Editing a comment
                The Atom is designed to be an on demand grinder with a hopper full of beans. That makes sense now why the bellows causes this issue inside the Atom. The Mignon series has a different chute and can handle the high pressure air from the bellows. The new San Remo All grounds May suite a bellows better.
              What we are seeing in those photos may (or may not) relate to an issue with the bolts for the upper burrs. Eureka installed too long bolts on the upper burrs. The top plate was drilled through, presumably to save problems when bolts on or just over the required length were installed. With the much longer bolts they stopped seals working properly and were especially bad with bellows. The solution was to install bolts which did not extend through the top carrier. Eureka was aware of the problem and offered replacement bolts (or as they are metric get from any hardware store in Australia).
              If we look at the throat of the grinder in question you can see the bolts extending well past the top carrier, probably by 4 or 5mm. This is probably the worst example I have seen on the net, most were 1 or 2mm. This would definitely stop the rubber sleeve in to the throat sealing well.
              Not sure if this is what we are seeing here but it is a reasonable guess.
              • lancruiser
                Editing a comment
                I may have misunderstood your description. I own a similar grinder, the "rubber sleeve" actually goes inside the top carrier. The seal is actually quite good.
              • 338
                338 commented
                Editing a comment
                Hi Lancruiser, I haven't owned a 75 like yours but I owned an Atom 60. My description was probably poor. There is a round rubber tube which goes in to the throat. It would hit the base of the throat and seal on the sides. As you can see on the base of the throat the bolt threads protrude pretty heavily, my guess why this 75 has the problems. I believe it affected a number of Atom models, no idea if the 75 was among them but the reason was a batch of too long bolts
              lancruiser you can see the bolts highlighted here and how they stop the the rubber sleeve seating correctly
                338 , I see.
                The "rubber sleeve" does not go down this far. There is a "landing" before that in the carrier that it sits on. See the markings on the picture below.
                Click image for larger version  Name:	20220711_151252.jpg Views:	0 Size:	219.4 ** ID:	920415
                This is the a picture with the gasket. Hopefully, it's not too dark.
                Click image for larger version  Name:	20220711_152529.jpg Views:	0 Size:	256.4 ** ID:	920414
                • 338
                  338 commented
                  Editing a comment
                  I see Lancruiser, makes sense. The 75 must be different to the original.
                  Here is a thread on the Mignon explaining the problem and Eureka's response saying they were aware and it was rectified - https://www.home-barista.com/grinder...t73522-10.html
                • San
                  San commented
                  Editing a comment
                  Can confirm, I have this year's Atom 75 and the screws are sitting flush.
                Well we got given a new grinder. Im going to take the top off in a week and see how it looks.
                Certainly when I looked on the old grinder it looked NOTHING like the above pictures.
                Sorry but that single dosing stuff is just a waste of time for us, we want an on demand grinder that works - I'm not willing to spend more money on something that this grinder should do easily.
                So far so good on the new one.
                • coffeemachine
                  Editing a comment
                  Lets us know how it goes with the new one. BTW, what grinder did you have previously before you purchase the Atom 75?
                Just the one built into the Breville machine, of which we never had an issue
