Grinder recommendation
  • LeroyC
    commented on 's reply
    When you get into the nitty gritty details you probably need to go and have a look at one or two of your options and if you can find a knowledgeable sales person have a chat to someone in store. Just note that bigger isn’t always better, although a higher wattage motor is usually something I’d be looking for. Lower RPM is actually better for grind quality, but needs to be balanced against convenience where something could just be painfully slow. Good luck b
  • rahmeleon
    Yeah I've not seen many of them either. Good to know that the X54 comes across as quality. What I struggle with is understanding why the X54 is about $300 more than the 55mm Specialita. X54 has a 120W motor vs the Spec's 310W. It also runs at 1050 rpm vs 1350rpm. The X54 has a WiFi link, the Spec does not. The X54 has 4 timer settings the Spec has 2. Thoughts?
  • rahmeleon
    Thanks level3ninja I'll have to take a look at the Atom 65.
    Thanks tompoland however the Silenzio doesn't have a timer function which I also require
  • LeroyC
    Originally posted by rahmeleon View Post
    Hi LeroyC I'm in the same boat as OP. But at up to $1500 what would U recommend if I am not single dosing? I looked up the HeyCafe H1 and if that had a timer I would've bought it. But what about the new Mignon XL? Is the price up from the Specialita worth it? How does it stack against the X54 or H1? I'm after a quiet grinder so I have removed the Vario from the list. No idea how quiet the H1 is tbh.
    I'm not really sure to be honest as I haven't seen enough of these grinders in person to make an informed recommendation. The one I have seen is the Mahlkonig X54 and while I was a little sceptical when it was released it does look to be great value. I haven't used it, but I've seen one and it's a nice looking unit that exudes quality which is more than can be said for some of the cheaper Eureka grinders and things like the Rocket Fausto.
  • tompoland
    Or the Silenzio ... name says it all really.
  • level3ninja
    If you want quiet look at the Atom 65
  • rahmeleon
    Originally posted by LeroyC View Post
    If I were you I'd get something that still has a hopper, but is capable of single dosing with good results and reasonably low retention. You may find the lack of a hopper annoying if you went for something like the DF64. For your style of coffee I think something from the Eureka range will be hard to beat. The others I'd consider would be the new Baratza Vario, the Mahlkonig X54 or the Hey Cafe H1. The Mahlkonig and Hey Cafe are over your budget at full retail, but I've seen them both on sale for around the $800-900 mark.
  • LeroyC
    Originally posted by Brissienew View Post
    Do you think for making milk coffee only, there will be a noticeable improvement with the coffee by upgrading from my BSG to either the DF64 or Eureka Mignon?
    It really depends on your palate. Some people would notice a little difference, others wouldn't.
  • Whorl
    Having done this upgrade a few years ago, I would say yes. A big yes. I upgraded from the smart grinder pro to the base model Eureka Mignon and it was a very noticeable difference.
    Edit to add that I primarily consume milk drinks (flat whites).
  • Brissienew
  • Toad
    Nothing wrong with the Mazzer as such, but noticeably less clumping with the Silenzia, also less mess and an lot easier - grind straight into the portafilter (with a funnel), tamp, done.
  • Seaperson
    Originally posted by Toad View Post
    I have just moved from a Mazzer Mini Manual to a Eureka Mignon Silenzio, and couldn’t be happier.
    if you are single dosing, there is no upside to spending an extra $100 or so on the Specialita.
    Yes, there is a bit of retention with the Mignon range, but show me a grinder with ZERO retention.
    And anyone that thinks they can detect the difference that less than a gram of retained grinds makes in a milk based drink is delusional (or James Hoffman!)
    What was wrong with your Mazzer Mini?
  • LeroyC
  • WhatEverBeansNecessary
    Differences in flat vs conical are pretty minor, particularly in milk.
    Also the Eureka Mignon Specilita would also be a good option. Maybe slightly more user friendly than the DF64 but not quite as good at single dosing.
    The Baratza would be a step down in grinding quality for espresso in my opinion.
    One criticism people have with the DF64 is that it is slightly 'hacky' - a few mods can make it a great grinder. Which is awesome if you like to tinker. but not so awesome if you don't or you have a partner that just wants low fuss and to be easy etc.
    However the DF64 has a larger burr set which has it's benefits too - grinding slightly quicker and perhaps slightly more nuances in flavour.
  • Brissienew
    [QUOTE]what roast profile do you typically drink;
    - I know you mentioned milk drinks but will it purely used for milk drinks; and
    - have you a preference for flat or conical burrs?/QUOTE]
    I typically drink Italian dark roast, making 2 cups of strong flat white at a time. There is no need for me to change the grind setting as I never make any other drinks. No preference for the type of burrs as I don't know the difference.
    The DF64 looks interesting, will look into it.
