Compak K3 or Ascaso I-Mini
  • rzyz2k
    Re: Compak K3 or Ascaso I-Mini
    Hi Andrew,
    I can vouch for the Compak K3 Elite (doser-type). I bought it for home use about a year ago and havent regreted it.
    To my mind: solid build, clean design, reliable consistent grind and good ergonomics.
    Phil
  • Secksy
    Thanks for that Stuart
    I didnt think of the i1. Im not sure what the differences in quality is to the K3, but youre right...Im sure someone out there will know.
    Regards
    Anrdrew
  • stuartgrant
    Hi Secksy,
    For what its worth, Id say the Ascaso equivalent to the Compak K3 would be the Ascaso i-home (i1), not the i-mini (i3). I have the i1 and its an excellent grinder! Very good for the price, Id say. I havent used the Compak K3.
    Having said that, most people (including Chris, I suspect) would probably still recommend the Compak K3 over the Ascaso i1. Perhaps they can tell you why?
    Stuart.
  • Secksy
    Thanks for that Chris
    It sounds like the K3 will handle any future espresso machine up-grades far better than the I-Mini might!  8-)
    Andrew
    Originally posted by Secksy link=1220092710/0#0 date=1220092709
    Hi all
    I need to up-grade my grinder but am being a little dollar conscious, as I would also like a new espresso machine in the not too distant future.
    I understand that the overall quality of the K3 is probably better, however, there is also $200 difference between them as well.  Does the K3 really grind a noticeable $200 better?  Or is it more a case that the K3 would last longer?
    I very much value your advice & comments before I make my purchase  8-)
    Thanks again guys
    Warm Regards
    Andrew
    Hi Andrew- Its an absolute no contest...The K3T by a country mile. Its a serious commercial quality grinder and frequently used for decaf in cafes. The i-mini, while good is much more of an appliance...With grinders, you really do get what you pays for...
  • Secksy
    started a topic Compak K3 or Ascaso I-Mini
    Hi all
    Thanks again guys
    Warm Regards
    Andrew
