I’m new to making coffee at home with machines more than $100.
I have a Moccamaster and will be getting either the Breville Bambino Plus or Dual Boiler to make Flat Whites and Iced Lattes with Oat Milk.
What is a good grinder to get less than AU$800? Looking for something that you can press a button to select single or double shot, and you can easily change between grind size for espresso and drip.
I was looking at the Niche Zero, but it looks like you have to weigh the beans before grind?
It looks like the Breville Smart Grinder Pro does what I’m looking for, but general consensus seems to be that you can get a much better grinder for a little more.
My wife who has never made an espresso before in her life will need to use the setup relatively easily.
Any guidance would be appreciated. Thanks!
