Difference between SSP Silver Knight MP and Red Speed MP Burrs
  • Difference between SSP Silver Knight MP and Red Speed MP Burrs
    Hi guys
    I am just trying to understand the difference between these two burrs. I get that they are two different coatings, but I see that the Silver Knights are generally a bit cheaper in some stores, so I've been wondering if there's a difference in quality. Or if the Red Speeds just became more popular and therefore go for a higher price even though the burr geometry is identical. I've seen some reports that the difference in the cup is indistinguishable. I've seen some suggestion that the Red Speeds run a bit faster or cooler, whereas the Silver Knights are harder... but I really have no concept of what the better choice would be for someone who will use these burrs exclusively for filter coffee at home.
    Hoping someone here knows more than I do!
    There's no difference in quality. I can't explain the price difference other than to say I'd buy whichever is cheaper.
    According to SSP, Silver Knight has a lower friction coefficient than Red Speed, and so produces fewer fines and is better for filter, while Red Speed is better for espresso.
    I used to have a set in SK for filter, did an excellent job of producing lip smacking acidity when I got it right. Can be punishing when you get it wrong. Helps to be seasoned with about 4-5kg, prior to that I found it to have an astringent finish that I couldn't get away from.
      Using SK burrs for both espresso and filter which produces excellent results for both....
        Thanks for your thoughts! After a day or so of researching, and finding no good reason not to just purchase the cheaper Silver Knights, that's what I'll be doing!
          Something I should also highlight, is that the burrs are super sharp, like a sharp knife, much quieter and at least 30% quicker than the original OEM burrs, An additional couple of benefits not often mentioned.
            I can't say quiet is a word I associate with MPs. They're about the screechiest burrs I've ever heard.
              Probably more to do with the actual audio frequency coupling and resonance of the case of your grinder.
              Definitely much quieter on my setup...
