Can't get Breville SGP fine enough
  • Can't get Breville SGP fine enough
    My neighbour has a Breville SGP and I went to help them dial in some new beans. I've noticed I cannot slow down the extraction enough even when the internal adjustment is on 1 and the side adjustment is also on 1.
    17 gms in and 40 gms out in 16 seconds. Also it takes around 20 seconds to grind that 17 gms, which seems rather high.
    Machine is 4 years old.
    Suggestions greatly appreciated as to what might be the cause. Would new Upper Burr Assy help? Or is it time for a new grinder.
    TIA
    Are the beans fresh and grind plenty fine enough in a known good grinder?
    If yes, I have heard of this happening, it's a manufacturing defect and Breville should replace it for free.
      Originally posted by gregeeh View Post
      TIA
      The problem is probably due to the age of your Breville SGP.
      In recent years Breville introduced a refinement in the hard set grind refinement settings in the SGP that makes it pretty easy to get finer settings with a twist of the bur - see video below:
      https://www.youtube.com/watch?v=QNvO...l=LifestyleLab
      As your neighbour's SGP is 4 years old it might not have that simple adjustment option. Contact Breville to see if they can get a couple of shims sent out (which raises the bottom burr) to fix the problem.
      • gregeeh
        gregeeh commented
        Editing a comment
        The grinder does have the adjustment mentioned in the viideo and is set at the finest setting, one. Sounds like a new grinder is required.
