I need to remove that upper rotating disk having 3 fins actually to clean it separately and clean what is under it don't need the motor itself .. I've just bought it and it is in a horrible condition and it needs hard work
Looks to be pressed on to the shaft, a three arm bearing puller with a very shallow angle of attack would be the weapon of choice.
Alternative (if you don't want the motor) is to drill out the shaft, a drill press will make that easier.
Thanks for answering my question
Actually I need the motor and I don't have that tool you told me about
I have a big hard screw driver I have inserted under and tried to push it up .. I think it moved a bit up but I was afraid to continue if I'm doing something wrong so I've posted here
Also if it is ok and I could pull it with this screw driver how will I put it back again with that force !!
