Wondering if there are any experts who can offer advice to help get this M2M up and running!
When switched on there is a faint hum noise coming from the grinder, once the red on demand button is pressed that is. The spring is not working on the button, but don’t see this being related.
I’ve cleaned out the grinder throughly to ensure it’s not clogged up.
And I’ve also opened the base to access internals and test the Capacitor’s capacitance as this from research can be an easy fix for some problems - in this case testing at 9.28 so it is within specification (5% of 10uF).
Is the motor finished and needing replacement? If so, I can’t find this part anywhere online. Not sure if worth fixing or cost prohibitive to do so. (It’s not under warranty).
Appreciate any advice or input.
