Eureka Mignon Oro First Time Use
  • kevviek
    commented on 's reply
    After running it for a while I can definitely say it grinds better than the Breville. Interesting though, I'm measuring retention at anywhere between 0.5-1.2g. Is that real world normal?
  • kevviek
    Burrs touching would be really bad wouldn't it?
  • Ironwoodbrad
    I have the XL , for espresso I am adjusting somewhere between 3 and 4 depending on beans and freshness.
    My burr’s touch at about 0.2 on the dial, There possibly is a way to zero the knob, but I have never worried about it.
  • kevviek
    Thanks. I've been increasing the coarseness, currently just under 4 and it's slower than ideal but getting close. I ran out of beans but have a fresh roast from 2 days ago to try in the morning.
  • bernardd
    Yes, I have the XL (same 65mm burrs) and I normally adjust the dial by just a couple of mm, 1/3 of a digit at most for a different type of beans.
    Still, there seems to be something else going on. You shouldn't have to go that close to the point where the burrs touch.
    As an indication, I do 2:1, ie: 18g for 36g of coffee out in about 30 secs. The grinding part takes ~10 secs.
  • level3ninja
    That's correct
  • kevviek
    Moving it from 3 to 2 completely choked my machine. It seems to be quite sensitive.
  • kevviek
    Thanks...I will try adjusting it by one on the dial tomorrow and see what happens
  • kevviek
    the single dose one. I assume the other is the XL?
  • level3ninja
    Which of the Mignon Oro models do you have? There are at least 2.
  • Berigora
    Looks like you need a finer grind. Depending on whether you drink ristretto or espresso you should be looking at 1.5 times or 2 times the volume out in about 26 seconds.
  • kevviek
    started a topic Eureka Mignon Oro First Time Use
    I just bit the bullet and got a Mignon Oro to replace my trusty Breville SGP. The manual is worse than useless.
    Is it simply a matter of weighing, grinding, timing the pour? I put 18g in today and had 50g out in 20 sec
