Super Jolly problems
    Re: Super Jolly problems
    Theres a good chance that they are genuine....
    Mazzer pretty well make burr-plates for all the various manufacturers and I imagine thats where CP would get theirs from. A quick message off to Pedro would sort that out though.....
  • vicroamer
    So CoffeeParts dont sell genuine parts
    In this case I dont know if the CP plates are genuine or copies, I wouldnt like to imply they were inferior to Mazzer branded plates its just for peace of mind knowing it will perform at its best I decided to ante up and pay the extra.
  • Sammus
    So CoffeeParts dont sell genuine parts? I was about to order a bunch of stuff from them but now Im not so sure...
  • vicroamer
    The new Plates have been installed and what a difference, faster and with a better tasting result, the old ones were well worn, grinding away rather than cutting. When I inspected the grinder I felt the plates needed replacing, however I had underestimated the price by about $20.00, I must have had a $US price in my head at the time, but its all turned out well in the end, new bearings and new genuine plates, Massimo is now working as Luigi intended.
  • ozscott
    Yep - go genuine (from what I have read).
  • vicroamer
    Sourced some genuine burrs, Mazzer 33d @ $75.08 + gst, Ill pay the extra and go with them rather than the cheaper non genuine.
  • yeeza
    Theyre a bargain from CPs I think you get spare change from a 40sheet from memory + shipping.
  • Martial_Monkey
    Contact coffee parts. Im pretty sure they sell genuine burs and the shipping doesnt cost that much.
  • vicroamer
    "It is possible they dont have genuine mazzer burrs in them"
    I think your right which is why I am trying to buy a pair of genuine burrs around Dandenong.
  • Martial_Monkey
    It is possible they dont have genuine mazzer burrs in them. I find the SJ (Played around a little on one) superior to the Rocky - speed, better grind, and a doser that works (for home use still would want to mod it so it sweeps clean)
  • vicroamer
    It turns out the silver I can get is two pack, that will be good enough for me, plus the price is right , also avoids the hassle of removing the stator and will look good as well.
    I have been useing it and I prefer the results of the Rocky :-?, the SJ tastes under extracted, though the grind is very consistent, it did a 30 second plus drip extraction without choking so it certainly can give a consistent grind but it lacks flavour, a bit slow to on a espresso grind as well, I am suspecting the donated grind plates, maybe they are generating a bit of heat and upsetting things, I think I need to fit new plates.
    Hi again "vr"...
    If you could strip the grinder frame down as much as possible, you would be able to drop the frame with motor stator into a motor rewind shop or auto-sparky shop and ask them to press the stator out for you. Should be a very straight forward task for them and you may even be able to persuade them to do it for you for a bagobeans... Worth a try anyway,
  • vicroamer
    Two pack would be preferable. Removing the stator for powder coating looks to be quite a job going by a thread I googled(below), the second last post links to the finished project. 8-)
    http://www.toomuchcoffee.com/index.p...olly+doserless
    There are some superb powder-coat colours available now "vr"; our local bloke has a huge range of metallics, candy colours, clear coats.... You name it. Also, there is always the "2-Pack" option. Some nice choices available there too... 8-)
  • Koffee_Kosmo
    You can get a name plate
    Stamp the serial number on it and pop rivet it on the underside
    If you can remove and re-use the serial sticker you can add that to the plate as proof
    Then you have a free hand to do anything even a Mazzer Mural
    Ha-ha New TV show pimp my grinder
