Help! - earth leak while roasting
  • #31
    Re: Help! - earth leak while roasting
    Thanks all.
    Curiosity will see me looking, but more than likely the motor will be tossed.
    Im now wondering if I can transplant a motor from one of the spare BMs because this one is the only one with a pan.
    • #32
      Originally posted by 4579647F757463767E75110 link=1233141776/30#30 date=1233574361
      Thanks all.
      Its a bit like can I swap a FORD motor to a Holden ?
      Model to Model etc can often be done as a driect swap out... However even that can be an issue when changes may have happened in a batch.
      Comes down to Motor specs and the control / drive cct... Then of course there is the issue of mounting etc.
      Note: Any thing is possible if you toss enough $$$ at it...
      • #33
        Originally posted by 17383133241B37383731333B333822560 link=1233141776/31#31 date=1233575658
        Or enough ducttape! : ;D
        Java "What time is it?" phile
        Toys! I must have new toys!!!
        • #34
          Originally posted by 0E21282A3D022E212E282A222A213B4F0 link=1233141776/31#31 date=1233575658
          Thats basically what I see as the main issue.
