Hello All,
I have been lurking for about a month now and soaking up the information , thank you!
My first post is a question about the capacity of the semi-commercial size roasters, 5, 10, 15, 25 Kgs.
For Example, a roaster is called the XYZ 10Kg .
Does this mean that the max amount of green beans you should put into it is 10kg resulting in about 8Kg of roasted beans,
or can you put 12.5Kg of green beans into it safely and produce 10Kg roasted.
I would assume the first, but a lot of roaster specs imply that the hourly output is 3x10Kg = 30kg instead of 24Kg.
Hope someone can set me straight.
Paul
Paul
. Your last comment is the accepted norm but of course most operators dont have the equipment or set up to be able to vary the amount of air flow (or type of air) from roast to roast to be able to check any differences that may occur as a result.
