Hey guys anyone out there using a Gene, If you have never pulled the chaff collector apart or you have not done it in a while this is a friendly reminder.
I was recently starting to have trouble getting even roasts with some beans black and oily and others not much past first crack. Also getting heaps of smoke well before first crack. Profiles were strange with the temperature reading not at all matching what was happening in the roast.
When I pulled the chaff collector apart the filters were completely blocked with fine chaff, both the inner filter and the outer filter needed a good brush.
Gene is working much better now.
P.S. There is also an inlet filter underneath the roaster that should be cleaned with a vacume from time to time. Mine wasnt too bad though.
Worked really well. Except the hair and the beard :
