Ive used Hazbeans FZRR 700 "Baby" roaster a bit and Ive used a slightly larger but essentially identical roaster (maybe Ill call it the toddler, since it is a bit larger!).
The information on the Baby here on CS says that the roasting process is different from other conventional roasters and this leads to different flavour profiles in the roasted beans; and leads to beans that can be used almost instantly.
Now, I basically agree with those observations, but Ive been wondering why. Having just done 250g of Malawi beans in the "toddler", the thing I noticed as the roast proceeded is that the atmosphere in the roasting chamber is very, very wet. The vent gas from the chamber felt like it was mostly steam. (The "toddler" has a manual crank to turn the drum, and the gas vents through the axle which is a piece of 1/4" pipe - so you get to enjoy the steam every turn >
Now, if you compare that with the Gene: the Gene has a very high airflow, so the environment within the roasting chamber would be quite dry. And the resulting beans (I would assume) would be much drier too. To a reasonable engineering approximation - the roast time and temperature profile for my Gene roasts and the closed drum roasters would be close to identical. The finished beans are virtually identical in colour too.
Just wondering if anyone else has roasted in a "wet" environment and can comment? Is this the hidden secret to the Baby?
/Kevin
)Now, if you compare that with the Gene: the Gene has a very high airflow, so the environment within the roasting chamber would be quite dry. And the resulting beans (I would assume) would be much drier too. To a reasonable engineering approximation - the roast time and temperature profile for my Gene roasts and the closed drum roasters would be close to identical. The finished beans are virtually identical in colour too.
/Kevin
But even so....
and am debating the closed "wet" system and the high air-flow fluid bed style. The general net.wisdom seems to be split 50/50 on the issue! Which really doesnt help!!
