Re: gene cafe not heating up fully
Thanks for the info and charts "hazbean"....
Helps a lot to engender an understanding of what might be going on. The Sawtooth" pattern of the rising gradient is indicative of On/Off Control through, not PID but it may use a basic Proportional design to generate the error to form the basis of control. As you say, there definitely seems to be plenty of thermal capacity available as there is no flattening off occurring on that steadily rising ramp.
Given all that, and the unfortunate usage of different specd RTD/Thermistor devices (most likely Thermistors as RTDs are considerably more expensive than $20), it should be possible to adjust the error voltage, or in code on the PIC to bring the unit back into within standard operating tolerances. One would think that this should be possible.
Also, is the Air Speed a controlled variable or fixed? As Kevin mentions above, thermal energy and air speed are intrinsically coupled and I was wondering if the management of this is more complex than just control of the element output alone? Would be great to grab hold of a Service Manual as well as a look at the PIC code - I wonder if there is one out in the wild somewhere.... :
) were the temperature sensors themselves. It made no difference to his machine.
