Seeking Coffee Roaster
  • don_nairn
    Re: Seeking Coffee Roaster
    at 2-3 Kg a week he will struggle to pay the rent yet alone make a wage unless coffee is a very small part of the business
  • artscendence
    I have a hottop Ill be selling for under 1k in the next two weeks (Will be listed in hardware for sale), brilliant machine for honing the subtleties associated with roasting. This will roast between 250-300g of coffee at a go and is a great place to start.
    Art
    Hi Sam,
    At 2-3kg per week, youre honestly wasting your time unless you can sell it at $100/kg. You need only to do the math.
    Id give up the idea of mucking around for your cafe and instead, see if you can source small quantities of interesting origins from your regular roaster or perhaps even a CS sponsor.
    If you want to learn, invest in one of the many small domestic roasters, play and learn at home and you never know, it may develop into something bigger.
    In a cafe, unless youre contemplating a minimum of a 5kg gas roaster or perhaps a set and forget solution like a solar autoroast, the numbers will simply never add up regardless of what small solution you employ.
  • Koffee_Kosmo
    Originally posted by 45686C606D010 link=1302315909/11#11 date=1302591827
    I dont think that is what Den is referring to KK....
    Pretty sure Den is suggesting that for such a small amount of coffee, the OP would be much better off in selecting one of our many prize-winning professional roasters blends. That way, there is no need to outlay any capital until such time as needs dictate...
    Thats my take anyway....
    Perhaps we should let the OP Sam to reply with more details
    One would agree that his information so far is a little thin on the ground
    At present he is looking at small home style roasters
    I personally think that for such a small amount of coffee (2 to 3 kg per week) it would be far more cost effective to buy the finished product from a roaster
  • cuppacoffee
    Originally posted by 4964606C610D0 link=1302315909/11#11 date=1302591827
    Originally posted by 53777E7E7D7D4753776B7577180 link=1302315909/9#9 date=1302581019
    Originally posted by 0117121203010D04040707620 link=1302315909/9#9 date=1302579297
    No, and I wouldnt be wanting to tell my customers that I roast my coffee on a piece of hobby equipment either.
    Sam at 2 to 3kg per week, you will wow your customers much more by using an excellent, commercially roasted coffee that is well prepared, than bragging rights because you roast your own.
    Thats quite fine if Sam
    1) Has the room
    2) Wants to spend many thousands of dollars
    Exactly Mal!
    I guess you took my post the way it was intended because you have nothing to spruik - thankyou.
    1) Has the room
  • Vinitasse
    In a small cafe or coffee outlet setting you probably wont have the time to dedicate to a manual roaster so I would definitely suggest you get a machine that is as hands off as possible. I think you might find that Coffee-Techs Solar Autoroast would fit the bill admirably. It has a very small footprint, is famed for the consistancy and ease of its roasts and looks pretty nice too. It will cost a bit but then again so does a good coffee machine.
    Another alternative is the Sonofresco / Greenbean roaster in 600g and 1.2 kg versions. This is a gas fired fluid air bed roaster whereas the Solar is an electric drum roaster.
    Both would suit the cafe environment and the task at hand and are available here in Au.
  • Koffee_Kosmo
    1) Has the room
    He may just want to trial the idea first before committing big cash and theres nothing wrong with that
    Just to clarify I was responding to Sams post where he stated the machines he enquired about
    Sam wrote
    ive been quoted 1200 for a hottop and 400 for a behemor so far. does anyone have any pros and cons for these?
  • cuppacoffee
    Originally posted by 486C656566665C486C706E6C030 link=1302315909/8#8 date=1302578181
    As a shop owner would you want to be roasting all day
  • Koffee_Kosmo
    Originally posted by 3F383C333B312434333A5D0 link=1302315909/7#7 date=1302573192
    There has been several recent threads on Behmor compared to Hottop to the Gene and also consider the KKTO at 2-3kg (USE the Search function here). All of them are really different roasters with weak and strong points and of course the one people own is always the best
    Gday again Sam
    My KKTO design has the highest payload of up to 700 grams or 800 grams for experienced users
    Higher payloads also equate in less electricity cost per roast and less labour time
    As a shop owner would you want to be roasting all day with multiple loads ?
    Sam it takes approx 30 min including prep & cooling time per roast
    Its simply the best value coffee roaster that consistently produces quality roast results
    Decision is yours
  • beanflying
    best thing might be is tell us where you are and try and get along to look at one or more options in the flesh
  • Carts9
    i anticipate only doing a 2-3 kilos a week in about 250g packs. Ive been quoted 1200 for a hottop and 400 for a behemor so far that sound ok. does anyone have pros and cons on these?
    Originally posted by 4E7176716C796B6B7D180 link=1302315909/2#2 date=1302333190
    Originally posted by 17352620276D540 link=1302315909/0#0 date=1302315909
    Does anyone have a small coffee roaster
    How small?
  • Koffee_Kosmo
    Originally posted by 6C4E5D5B5C162F0 link=1302315909/0#0 date=1302315909
    Does anyone have a small coffee roaster they want to sell or know where i can get one thats affordable for a small cafe outlet. Cheers
    Not enough information in your post
    I am going to assume that you are a cafe owner and a small roaster may be anything from a 1 kg to 10 kg roaster
  • don_nairn
    Perhaps some sort of guide to how many Kg a week you are using would be a start.
    a Behmor is about $400 but if it would be subtable I have no idea.
    in the scheme of things it may be sipler to find a good commercial roaster (company) that can look after that part of the business. After all you cant do everything yourself.
    small roasting as a hobby is good fun but can you make good money from it?
  • Vinitasse
    How small?
