Originally posted by robusto link=1121040424/105#113 date=1126827595
If they cant be removed then any kind of a plating option is out as the barrels themselves cant be removed so-as to prevent them from being plated (not to mention to prevent them from being exposed to the chemicals in the various plating baths). Given that the roaster is 50 years old I have serious doubts about whether Ill be able to remove the screws holding the outter covers on. I tried to remove several of them prior to it being blasted and none of them gave even the slightest bit.
If I *had to remove them the heads are big enough that I could lock a vice-grip on them where-upon they would either come out (while ruining the appearance of the screw head requiring their replacement) or the heads would twist off where-upon Id have to drill them all and attempt to pull them with an Easy-Out. Failing that working Id have to drill them all out and re-tap the threads. If I cant find a high temp paint I can live with it may come down to that but I fervently hope not!! As I recall theres 11 of these screws per barrel assembly. I *really dont relish the thought of having to drill out and re-tap 33 screws/holes. But Ill do it if I have too.
Java "Looking at all the options" phile
