Re: A (Epic?) journey in search of my perfect roas
LOL I kinda fall into both camps. I not only love to tinker with the rebuilding, I also love to use the equipment. I get to tinker with it even more that way! ;D
Theres nothing in this restoration/rebuild that I couldnt do given the neccessary equipment. From the construction of a new box (straight forward geometry and basic sheetmetal working abilities) too stripping and plating the existing box (I used to work in the R&D lab at the worlds foremost high-end PCB manufacturer where we plated using everything from copper, to nickle, to gold).
Unfortunately I no longer have access to their 5,000 gallon stripping and plating tanks, nor to a sheetmetal shop or sandblaster so Im relegated to paying for these services. :-/
As many tools and devices as I have I dont have them all....D*mnit!
Im still hoping to be able to start testing the roaster by next week-end.
The current plan is to take the roaster up to the Sodablaster on Monday and hell do it while I wait. When I get home Ill then paint the inside of the flame chambers. Then while the paint sets up and cures Ill be working on getting the motor operational which may be as simple as dropping one of the 3-phase legs off and running it on 220 single phase. From the sounds of it Id end up with a motor turning at 1700 rpms instead of 1400 with a third less power and that would prolly need a hand getting started.
This may or may not work. I wont know until I try it. The power of the motor I think is more than needed and if they ran it as it appears with no oil on the barrel shafts properly lubricated it will most likely require half as much energy to keep it all turning once up too speed. Given the already high rpms of the barrels (Gothots traditionally ran at about 60 rpms) the added rotation may not have much of an effect on the roast. The additional speed of the turbine wont matter as the air flow is adjustable on each barrel independant of the turbine.
So at this point the determining factor looks to be the curing time of the paint. What that is I dont know yet as Ive not bought it.
Java "Onward and upward!" phile
. The motor will draw way too much current and burn the windings out in pretty short time. Hope this helps out a bit and maybe avoids setting fire to your roaster in a way you havent planned on
