What do YOU use to home roast?
  • Sunbeamer
    Re: What do YOU use to home roast?
    that was 19mins to 2nd crack (probably well into 2nd, I still have lots to learn here) on 250g
    I will admit it looks a lot more even in real life, I think its a flash thing there, I will get better pics when the beans come out of resting
    I originally had 3 flaps to help stir it up but have since flattened them down as they were throwing the beans around and making a lot of noise so you couldnt here what was happening, the beans look to still be getting mixed well but I think I will need to add something to help stir them up some more as I think beans down the lower end are staying there and the higher end would be getting more heat exposure
  • robusto
    Yes, the uneven roast looks to be a problem. A shroud, with less flame, may be the solution. The mas appears to be getting stirred quite well.
    How long is the roast, Sunbeamer?
    Are there agitators in the drum?
    -Robusto
  • segrave
    Maybe there is a little too much direct as the roast looks a little uneven
  • Sunbeamer
    yes orginally I planned a shroud, but empty testing showed it may be a little too much heat
    I think now though I am pushing the limits on a still day so the shroud is getting knocked up this weekend
    the shroud material you ask? 1kg tin of Nescafes finest, the mighty 43 beans ;D 8-)
  • robusto
    Not bad Sunbeamer, especially for the pricely $0. The thermouple gives if a high-tech look of sorts.
    Theres an awful lot of heat loss though ... have you considered an equally cheap shroud?
    -Robusto
  • Sunbeamer
    Hi all thought I would post up some pics of the contraption I have cobbled together based on what I had lying around and pics of what others have done here
    the drum is a recycled Nescafe decaf tin (see nescafe is useful) and the mesh nicked off a truck airfilter
    its spun by my cordless drill held on with a ziptie and heated by my trusty camping stove
    total cost to date $0  8-) ;D
    The final result of my 1st real roast, 250g of Brazil Peaberry
    heres a bit of a video of it in action, right click and save as (2mb)
    http://www.auszookers.com/royce/roaster.avi
    I noticed looking around I might well have enough bits to make up a HG and paddle in a bowl type setup so that might be next cause I am not real keen on running the drill real slow next to a flame as it isnt really a cheap drill
  • Ray_C
    I also am in the process of building a bench top fan forced roticerie convection oven raaster to take over from my ever so reliable popper.
  • smoky
    Thanks to all for such good info, and thanks Thundergod for those links, very informative from what Ive seen so far.
    Cheers..........Stu
    Look in the Home Roasing section manually if you have to but heres a few to get you started:
    http://coffeesnobs.com.au/YaBB.pl?num=1171622615 (has link to a video of roasting)
    http://coffeesnobs.com.au/YaBB.pl?num=1164028430 (breadmaker reviews)
    http://coffeesnobs.com.au/YaBB.pl?num=1164000407 (heatgun reviews)
    http://coffeesnobs.com.au/YaBB.pl?num=1174636354
    http://coffeesnobs.com.au/YaBB.pl?num=1170221386
    http://coffeesnobs.com.au/YaBB.pl?num=1170472435
    http://coffeesnobs.com.au/YaBB.pl?num=1169639005
    http://coffeesnobs.com.au/YaBB.pl?num=1167177851
  • Dennis
    Smoky, you also need to consider a few other factors - eg. how your personality matches your roasting technique
    I found a popcorn maker was just too slow for me and didnt produce anywhere near what I needed. It can be mesmerising to the point of making you dizzy!
    The HG, colander, and balloon whisk method is great - I like roasting beans with this way because it is so tactile and you have quite a lot of control re the results. I never upgraded to a BM so cant comment there
    The Gene is terrific, and though the initial outlay is high, i can see it paying itself off many times over - very even, decent sized roasts that you can just about walk away from, and some people do...then again, I find I come back toward the end of the roasting process just to make sure Im satisfied with the colour and because...I like to watch
  • smoky
    Would do Mal, but search site on here doesnt want to cooperate.... :
  • smoky
    Point taken Belinda, yes, it has me going out this week to look for a 2nd hand bread maker, only trouble I can see, and know where I can get a good heat gun for a good price, dont have a Bunnings out in this dump, but sure I can pick one of those stands up for around that price; yes, sounds like a good idea indeed...........
    Gee,
    300 grams in an hour.... Ive done about a Kilo in that time :P. Actually Smoky, if you do a search for threads on Corretto roasters youll turn up a wealth of information. Even though I got in on the act pretty early on in the piece, there are plenty of others who have done much more with their setups than I have.... Mine is still pretty basic by comparison .
    The Search tool is your friend 8-)
  • Corretto
    2nd hand breadmaker for under $50.
    Good heatgun for $50 to $100.
    Drill Press from Bunnings $12.
    Under $740 easy Id say ;D
    Yes plenty of threads on this about the place.
    Belinda
  • smoky
    Sounds like a good idea Thundergod, but expense is my question, as by the time you buy a bread machine and a heat gun, would it not be around the cost of a Gene Café, which Ive found as low .... as $740.
    Need to convince better half with a lot of data about the different types before making a monetary commitment... :
