Well, its finished!
Found a cylindrical stainless steel bowl (Best description I can give, as its not a canister), drilled a hole in the bottom for the shaft. Drilled it slightly smaller, then hammered the shaft through to make a square hole. Drilled four small holes for the prongs, to secure it to the shaft. Drilled some holes for a number of 1/4" bolts and nuts to act as agitators. Drilled a bunch of 4mm holes to make the drum slightly perforated.
The cap is simply the lid to a stainless steel pedal bin. Drilled the hole for the shaft the same as above. Instead of drilling the holes for the prongs, I used the prongs to secure the lid to the drum. The thumbscrew is easily accessible, and doesnt get too hot. To dump the beans, I remove the spit from the motor, loosen the thumbscrew for the lid, and slide the lid off. Beans are dumped into the colander for cooling.
Ive done one small roast (300g) and it works a treat. A bit of unevenness in the roast, but I was still fiddling with heat control.
