Information / Reviews of heat guns
This is a sticky topic.
  • #16
    Bosch vs Makita HGun
    Bosch PHG630DCE vs Makita HG1100
    Any observations re pros cons?
    Makita (139$)
    Features:
    • 2,000W of flameless heat
    • Variable temperature control 100–600°C
    • 2 speed blower fan
    • Perfect for stripping paint, varnish and many other applications
    • Ceramic core protects the heating element
    Specifications:
    • Air Temperature: 100-600°C
    • Air Volume - Hi 500L/min
    • Air Volume - Lo 300L/min
    • Amps: 8.5
    • Watts: 2,000W
    • Overall Length: 254mm
    • Net Weight: 0.6kg
    • Power Supply Cord: 2m
    Includes:
    • Filter cartridge
    • Hose
    • Paper bag x 1
    • Disposable plastic waste bag x 1
    Bosch (105$)
    Features:
    • Digital display for temperature display
    • Temperature control via buttons: operating comfort
    • Softgrip
    • Bosch Thermal Stop: unique overload protection
    • Removable protective pipe
    • 3-stage switch for one-handed operation
    • Stationary working also possible
    • Free selection: air flow and temperature independent
    • Temperature is easy to control
    • All switches are easy to reach by hand
    Specifications:
    • Power input: 2.000 W
    • Temperature: 50 – 630 °C
    • Airflow: 150 / 300 / 500 l/min
    • Machine weight: 0,9 kg
    12 MONTHS WARRANTY
    Runfast
    • #17
      Re: Bosch vs Makita HGun
      Off topic replies have been moved to [link=http://coffeesnobs.com.au/YaBB.pl?num=1196723544]This Thread[/link]
      • #18
        Re: Information / Reviews of heat guns
        Off topic replies have been moved to [link=http://coffeesnobs.com.au/YaBB.pl?num=1198760060]This Thread[/link]
        Cmon guys..... This is an Information Thread only, if/when you would like to discuss the pros or cons, or any other aspect of the use of heatguns please start a new thread in the general NON-Sticky area,
        Thanks,
        • #19
          Metabo HE2000.
          Well, someone had to do it.
          Heat Gun Name / Model Number:   Metabo HE2000.
          Price Range (specify new or 2ndhand):   Lots, $180+ new.
          Place of purchase:   I got this off the Evil One for under $80.
          Length of warranty:   One year with an extra two years if you register on the Metabo web site.
          Power Consumption: 2000W.
          Fan Speeds:   3.    250/270/500lt/min.
          Heat Range (if applicable):   50-600*C.
          Length of service (how long have you been using, how long did it last?):   Since late 11/07.   done about 10 roasts.
          Notes:   Made in Switzerland. (yes, you read it right, Switzerland!)   If this lasts as long as the Swiss hammer drill I bought in 1977, Ill beat it to the grave.   Pros - plastic heat shield that protects the element, is removable.   Two removable air inlet filters.   Infinitely variable heat setting.   Cons  - The same infinitely variable heat control (sliding potentiometer) is too stiff to get to the same position with any accuracy (I use it flat out to avoid variation).
          b4b.
          • #20
            Off topic replies have been moved to [link=http://coffeesnobs.com.au/YaBB.pl?num=1206851160]This Thread[/link]
            • #21
              Heat Gun Name / Model Number: Ozito OZHG2000WAK
              Price Range (specify new or 2ndhand): $40 New
              Place of purchase: Bunnings
              Length of warranty: 3 Year
              Fan Speeds: 2 (250 L/min 450 L/min)
              Heat Range (if applicable): 70 - 600 degrees C (claimed see below)
              Length of service (how long have you been using, how long did it last?): Just got it.
              Notes:
              Well finally, a cheap variable heat gun. And thats exactly what you get.
              The low setting is useless. Even on the hottest setting you stick you hand in front of it.
              The variable heat settings are not linear. The dial turns through 12 of the tear drop shapes. I stuck a thermocouple on the end and here is what I got (high fan setting):
              0 - 60C
              2 - 100C
              4 - 230C
              6 - 270C
              8 - 340C
              10 - 410C
              12 - 480C
              • #22
                [split] [link=http://coffeesnobs.com.au/YaBB.pl?num=1264392257/0#0][splithere][/link][splithere_end]
                • #23
                  Heat Gun Name / Model Number:  Ryobi EHG2002LED
                  Price Range (specify new or 2ndhand):  $75 new
                  Length of warranty:  2 years
                  Fan Speeds: 2
                  Heat Range (if applicable): 50 - 650 degrees variable
                  Length of service (how long have you been using, how long did it last?):  1 week. No roasts.  :-/  Stopped working the first time I used it.
                  Notes:  HG died when I turned it off after running it at 650 deg for a few minutes. A small whiff of smoke then it wouldnt go anymore. Will try again after warranty exchange.
                  • #24
                    [split] [link=http://coffeesnobs.com.au/YaBB.pl?num=1292991494/0#0][splithere][/link][splithere_end]
                    Please Note: NO discussions in this thread....
                    • #25
                      Heat Gun Name / Model Number: Bosch GHG 660 Professional
                      Price Range (specify new or 2ndhand): $135 New ($140 List Price)
                      Place of purchase: Sydney Tools
                      Length of warranty: 12 Month
                      Power Consumption: 2300W
                      Fan Speeds: 10 (250-500L/min)
                      Heat Range (if applicable): 50-660 deg. C in 10 deg. increments
                      Length of service (how long have you been using, how long did it last?): 3 roast so far
                      Notes: Toyed with the value of a "professional" model over the 630 for $100...think the great fan-speed control is worth it.
                      Photo (if available):
                      • #26
                        XU1 mods - be careful!!
                        Hi all.
                        I thought I might put this in the heat guns sticky as it is a trap for young (inexperienced) players.
                        I bought a XU1 to pull apart and separate the "heating" from the "blowing" so I could control the heat via PWM. In doing so I managed to blow up the unit. It's really a design defect, but unless you pull it apart the defect is unlikely to show up.
                        See attached photo. It's the handle-end of the heating element. The over-temp cut-out is situated right next to one of the 240V terminals on the element. The terminals are riveted in place, but can be turned with slight pressure. The body of the over-temp cut-out is connected to the neutral line, so if the terminal with the black wire is rotated anti-clockwise enough to touch the cut-out switch, it short-circuits and blows the unit (and maybe also what you have connected to it). I think it happened to me because I pulled on the wires a bit when re-installing the element.
                        So,
                        if I hadn't pulled it apart, it wouldn't have blown up
                        if the body of the cut-out wasn't metal and connected to the neutral line, it wouldn't have blown up
                        if the cut-out was no-where near the active terminal, it wouldn't have blown up
                        if the active terminal couldn't rotate, it wouldn't have blown up.
                        Gonzo
