ROASTER ADVICE
  • ROASTER ADVICE
    Looking at buying a 2.5 kg toper roaster are they any good. If not what is joper, probat, etc
    Re: ROASTER ADVICE
    Are you going to use it for home roasting or commercial roasting?
      Re: ROASTER ADVICE
      At home to till i get the hang of it and the commerical
        Re: ROASTER ADVICE
        Talk to Les Hawker, up at Coffeeroasters...he is a sponsor, and deals with Has Garanti roasters mainly. He should be able to give you some advice. Depending on what you want to achieve, there is a big difference in price and quality between the various brands.
        The most important factor however, is your roasting skill. Any roaster (the machine) can produce good results, given an expert hand....
          Re: ROASTER ADVICE
          Coffee Roasters Australia
          http://coffeesnobs.com.au/YaBB.pl?num=1163932474
            Re: ROASTER ADVICE
            You could also talk to Serge at Go Barista
            www.gobarista.com.au
            He is a master roaster and sells a range of commercial roasters (does training etc as well)
