roasters capable of 1 lb
  • roasters capable of 1 lb
    I am very happy to have found this site as everyone is in the same boat: to frankenstein a roaster using easily available resources. Currently using the Corretta method and am more than happy with the beans; however, I hope to be able to roast 1 lb in order to sell a few beans. Without having to buy a commercial model, what are the possibiblities ? Has anyone tried this? Another possibility is the rotisserie with a modified drum. This is readily available in North America but I have not had much feedback on these. Any ideas would be welcomed.
    Keith
    Re: roasters capable of 1 lb
    Gday beanhere,
    Glad to see that you are a Corretto convert, fantastic way to roast beans at home 8-). Most of our members here in Oz who use the Corretto are already doing 1-2 lb roasts so Im surprised that you havent tried that amount in yours as yet.
    A couple of us even have Bread Makers that could probably roast as much as 3 lb providing a suitably robust heat source was available, one chap is using 2 HGs with his so 3lb roasts are probably not far away.
    What sort of combination do you have there BH? Might give us a better idea of how to go about giving you some ideas.... maybe a couple of photos would help too. All the best mate,
      Keith,
      I havent used the Corretto method, but I think it can handle pretty good volumes.
      I think the drum method is also a great way to go when looking at larger volume unless you want to shell out VERY big bucks for a sample roaster.
      I personally use a SS mesh drum fabricated by a friend of a CS member over 2 years ago. Its been a faithful servant ever since.
      I roast on our 4 burner BBQ and usually roast 720g green which comes down to around 500g once roasted. I have done a kilo once or twice and the results were fine, but I rarely NEED to do that much at once and I feel more comfortable in my 720g range. Also, many of my timings have been done with this weight, so I have a better point of reference.
      Many people here have built drums using a variety of products.
      A converted roasting oven.
      A SS waste bin from Australia Post.
      A Large Milo tin.
      I seem to recall Chris (2muchcoffeeman) mentioning that he had someone who might do some fabrication as well.
      Short answer, Im sure you could find something here without having to order a drum from the US.
      Brett.
        Would it be this one Mal???
        http://coffeesnobs.com.au/YaBB.pl?num=1159261359/45#45
          Aarrgh matey,
          Yep, that be the one
            I just want one of Les 1kg Toper roasters... 8-)
              I wouldnt mind one too :P
                Id have it for the chromework alone if nothing else.
                --Robusto
                  Time to go dip my TOP roaster in chrome then...
                    Here is a drum I made a week ago from:
                    2x 15cm diameter aluminium sieves (to form the ends)
                    4x 20cm long L-shape brackets (inside drum for bean agitation)
                    Stainless steel mesh (6.5mmx6.5mm). Had to wrap around twice as holes were too big.
                    and other things
                      Looks like it came as an accessory.
                        nice rig there wushoes - now the wait for the beanbay delivery
                          you havent seen the imperfect workmanship closeup :P
                            I saw your other pics.
                            But from that shot it looks great.
