How should i start?
  • How should i start?
    Hi everyone,
    I want to start trying to roast the bean at home. However, i dont know how to start? Do i really need to purchase a roaster? Or can i just use my oven at home?
    Also, i want ask is a roaster really do a better job than the oven and popcorn machine? I only use max 250g of coffee bean a week.
    Re: How should i start?
    Pan roasting in an oven does not work very well.
    Might I suggest you start by reading these threads:
    http://coffeesnobs.com.au/YaBB.pl?num=1154442377
    http://coffeesnobs.com.au/YaBB.pl?num=1174699442
    Java "Roasting made easy" phile
    Toys! I must have new toys!!!
      For 250g a week a popper is probably all you need, but you should consider the coffee snobs "coretto" method, eg a bread maker and heat gun.
      You can easily do 500+ gram roasts, you get great control and most here would agree that the results equal that of commercially made home roasters.
        Sound like i have i invest some money to get a descent roast~~Thx anyway. Ill have a read of those two thread first and see how it goes.
          Not at all. I spent $20 on a used dodgy breadmaker and $45 on a used pro heat gun. You could probably do better than that, at least on the heat gun... $50 or so barely makes a dent in your coffee budget.
            I started with a popper and it worked well but you are limited to 100-150g at a time, I graduated to a Corretto when my popper died and it is great. I roast 400-500g at a time now and get nice even roasts and it is easy to do......................
              Yep Id agree
              After using my corretto setup, I find it hard to come up with a good reason why I would use my popper again!
              At least the kids have their popcorn maker back! 8-)
              Andrew
                See my story and picture on thread "cheap modified corretto"
                Before this I used the same heat gun, but put 300-400 g of beans in a stainless steel bowl. I donned my Ipod, listened to the radio ( just loud enough so I could hear the bean cracks) and stirred with a metal whisk for up to 15 mionutes. I put on leather gloves, and cooled the roast by pouring the beans between two metal colanders in front of a fan on high speed.
                It was a simple, cheap and effective setup, albeit labour intensive....but It was still far preferable for me than the popper, which rarely gets used these days.
                Gary
                  Thats what I thought initially too Andrew,
                  As it turns out though, they come in handy for when I need to "test" roast some small batches of a new bean or a new crop of an old favourite, just to make sure I get the main roast right when the batch sizes get upped to 600-900g in the Corretto. I wouldnt pass them on, just yet....
                    just wondering which brand is gd and cheap (Both heat gun and breadmaker). Also how do i cool the bean if i use the coretto method?
                    So i have to spend around a hundred for this setting?
                      Thats a fair point Mal...I didnt think of that!
                        Hi Sugilun
                        Second hand Sunbeam Bakehouse Compact - $29
                        New Ozito heat gun - $30
                        Pedestal fan - $15
                        Enjoying my own freshly roasted beans - PRICELESS 8-)
                        Andrew
                          A popper is about $20 - $30 wherever you get it from.
                          A thermocouple etc is about $25.
                          All up the cost is about $60.
                          Its how I started.
                            I started with a popper and never used a temperature probe with it.
                            No problems with that setup what so ever.
                              just wondering, where can i buy second hand bread maker?
