"DreamRoast" 1kg+ Custom Coffee Roaster
  • "DreamRoast" 1kg+ Custom Coffee Roaster
    Have done a few improvements. Added a rim for sitting the turbo oven top in using bands of aluminum with a high temp. silicone tubing gasket. Cut down the roasting pot to 4" deep. The Turbo oven top has been rewired with the heating element and the convection fan direct wired to the "F" and "H" toggle switches. The heater line goes down through the controls and variac. Can now roast up to 1300gr. with a good profile.
    Re: "DreamRoast" 1kg+ Custom Coffee Roaster
    It just gets better and better.
    Great size for a home roaster too. All the domestic roasters soon suffer from not keeping up with the volume required, 1kg would do most people and their family/friends fine.
    How do the roasts compare to your blower roaster?
      Andy With the many adjustments I can do with this roaster, many profiles can be obtained. The top heater adds convection the lower heater adds conduction and both can be adjusted. The variable speed motor for the bean bats allows perfect evenness at any size batch. Im not much for "set it and forget it" type machines. A BBQ drum roaster is not a good option for me for larger batches as winters in Massachusetts are very cold. "blower roaster"? maybe you are thinking about Chads aka seedlings roaster? Ed
