Re: Re: Heatgun Discussion.....
My guess is that professional painters and decorators probably would.... but they wouldnt dream of using a GMC.... it would be a Bosch or even better. And even then I dont think it would be that long in a corner - however corners would be more open than a narrow BM bowl (more like the dog bowl method of roasting).
But for the domestic market and domestic users... which the GMC is designed for.... I doubt it. My arms would be tired from the constant heating and scraping well before that..... not to mention the heat and fumes in your face. And as soon as you switch off, it will thermal out and not allow you to switch on again until it has cooled down.
I have, amongst other light duty GMC equipment, a leaf blower vacuum... which works great - but with thermal out when attempting to restart if pushed for too long (and that is what I expected from something thats cheap)..... now if I kept using it non stop for 20 minutes.... it would probably go into terminal melt down!! Seeing the manual warns you that it may overheat and will need to be rested (I dont have a GMC HG but Id be sure its manual does as well).... then failure to do this would be abuse of the item.... and not covered by warranty.
;D,
