How inferior is a Popcorn popper?
  • #16
    Re: How inferior is a Popcorn popper?
    Originally posted by Koffee Kosmo link=1217409835/0#14 date=1217481263
    I have roasted and still do on occasions in a small pot or wok over the BBQ wok burner
    I use a long whisk for stirring the beans and it’s relaxing
    This method does a surprisingly good job
    One does not need any special equipment to achieve great results
    That really is just so wrong. :P
    • #17
      Ill second that.
      • #18
        Ezra just wants to give roasting a try
        He can do it for free or little cost when starting off (popper)
        If it was me I would prefer a Gene or Hot Top
        "But thats not the Post question"
        • #19
          KK would you add a bit of Black bean sauce with your wok burner method?
          I would think you would be baking the beans and not roasting them using that method
          • #20
            Marty
            Anything is fair game when I am desperate
            I have worked in enough cafe kitchens in past years to know how to handle heat
            But now, I mostly resort to a bowl with heat gun as a last resort
            • #21
              My thoughts exactly. No need to over-complicate it just yet. That will come later. To quote Andy in that article with some news mob, all you need is hot air and agitation.
              • #22
                NTE
                Thanks for backing me up on this [smiley=engel017.gif]
                And a great quote from Andy [smiley=vrolijk_26.gif]
                • #23
                  Im not sure thats entirely true.
                  If it were, with all the hot air and agitation here at work, I should be knee deep in roasted beans.
                  • #24
                    Stand Back - Im roasting right now!
                    • #25
                      I guess when I said an iRoast is just a glorified popper I didnt meant to bring in any complicated arguments, I guess I was just answering the question as: although I havent any hands on experience of both methods, Im fairly confident a popper roast and iRoast2 roast are fairly similar.
                      • #26
                        Based on what experience, exactly?
                        • #27
                          "I guess when I said an iRoast is just a glorified popper I didnt meant to bring in any complicated arguments, I guess I was just answering the question as: although I havent any hands on experience of both methods, Im fairly confident a popper roast and iRoast2 roast are fairly similar."
                          I think this is a bit unfair to the iR2. We noticed a significant improvement in
                          moving from a popper to an iR2 (this was after several months using a couple
                          of poppers). The iR2 is actually a good design in many respects, especially
                          in how it moves the beans in the airflow. When properly tuned, it does a
                          very good roast. Its disappointing that Hearthware failed to put  the
                          extra effort into design and implementation refinement to make it perform
                          to its capabilities. Actually, it does a pretty reasonable roast even in its
                          standard "too hot" state, whats frustrating is that the promised programmability
                          isnt delivered in that state and the range of achievable roast profiles is limited.
                          The iR2 may use the same principle as a popper, but it refines that principle
                          to a point not possible with a popper. So, generally speaking, it does a better
                          job than a popper.
                          The original poster asked if an iroast would do a better job than a popper.
                          I think, yes. However, I would advise care in forking out for one on a
                          limited budget not because its a bad roaster, but because it takes a lot
                          of effort to get it to its potential (I know, I worked at it for nearly a year),
                          and because its somewhat unreliable.
                          • #28
                            Thankyou hazbean -- have never used a popper myself, btw.
                            Slightly OT -- somewhere in a related thread you mentioned trying a variac with your iRoast and being underwhelmed by the result. Sadly I had rather pinned my hopes of iRoast resurrection on this being the answer -- we have a variac somewhere in the shed, just havent been able to find the wretched thing :-/. Did you try this before or after your resistor (and other) mods?
                            • #29
                              The variac came later. I didnt have one at the time I was doing the mods,
                              otherwise I would have tried that first.
                              The variac does help, just not as much as Id hoped. The experiment I did
                              was to first do a roast with an unmodified iR2 at 240V with a program of
                              160/5; 200/3; 220/3. FC at 3:30, TC reading 214C; SC at 5:50, 235C.
                              Then the same dose again (120g MT Bundja) at 220V. This gave FC at 6,
                              which is a good improvement, but I noticed that the beans (even with this
                              lower than usual dose) were not moving very well.  Then the temp plateaued
                              at 228C and progress seemed slow, so at 9 mins I kicked it up to 240V and got
                              SC at 10:00/236C. The roast was OK, but I think with the slower movement
                              there is some risk of tipping and scorching. But I think if  I had left it SC would
                              have arrived at 11 to 11:30, which isnt too bad.
                              I concluded from that that a variac setting of about 230V would be about the
                              best that could be done, probably giving 9 to 10 mins roast time. A definite
                              improvement, but not as good as the 12 to 14 mins I could get with a
                              suitable calibration resistor in place.
                              (The reason I was using a small dose was to see if the iR2 was suitable to get a
                              light "cupping" roast. The "official" spec for this is a light roast in 8 to 12
                              minutes. No luck unfortunately. I have since figured out how to roast 100g
                              or so to that level in the Gene, but in about 15 minutes. Close enough I think.)
                              A few days later I cupped the two Bundja roasts against each other and one done
                              in the Gene. There wasnt a lot between them, but Bundja is a little idiosyncratic,
                              it can throw different flavours from ons shot to the next, so cant be definitive.
                              • #30
                                Hi Hazbean, thanks for the extra detail.
                                Not a magic bullet, then
