1kg home roaster
  • #16
    Re: 1kg home roaster
    Originally posted by 535547494C554E200 link=1257649167/11#11 date=1257660455
    Also, How do u connect the motor to the power outlet?
    Before attempting this please provide your details and story on the following form :
    http://www.darwinawards.com/slush/submit_story.html
    Cause of death could be electrocution or incoming rant by AM.
    • #17
      Originally posted by 383E2C22273E254B0 link=1257649167/14#14 date=1257661138
      Where can i get the transfomer? Jaycar?
      I lived in China for a few years and have one that I happened to bring back with me.
      It is a pretty heavy duty one but im not sure of its specs off hand.
      • #18
        These are the drawings I did last year for a similar project
        I went the Turbo oven path instead
        However you and others are welcome to my drawings of the drum/sample roaster
        Using an off the shelf small BBQ
        Engineering work required
        Sides of lid to be reinforced with plate incorporating a solid bearing guide for turning drum
        Hinges to be re-positioned to the left side of the roaster
        Drum & drive motor to be fixed to lid but removable for service - when one lifts or lowers the lid the drum goes up and down  as it is attached to it
        Vanes need to be fitted inside the drum  to agitate the beans
        BBQ galore have these portable units with 2 gas burners for $199
        http://www.barbequesgalore.com.au/products/product-view.aspx?id=1086
        Drawings attached
        • #19
          Hi CSrs,
          I am interested in a gas fueled drum roaster.
          The idea has been smouldering in the back of my thoughts for some time and after harvesting a small single burner BBQ from the roadside has started to take a more concrete form.
          Q for KK I am interested in your thoughts and drawings.
          The BBQ that came up in the link has 2 X 9500Mj burners. Im a bit vague on rated energy/power values but if Im not up the wrong tree, LPG BBQ burners probably go from about 9.5MJ or 9,000BTU up.
          2+ burners should be enough grunt for commercial volumes of beans.
          Have I got this right?
          Q for Matt H,
          From your 750g brown experience.
          What energy input and burner (or device) do you use for your heat source?
          What heat time profile do you follow?
          I have been a Corretto roaster most recently but Im a newbie all through.
          Kind Regards
          Lindsay
          • #20
            Originally posted by 2623242E392B33382B4A0 link=1257649167/18#18 date=1257676004
            Q for Matt H,
            for 750g roasted I put in about 930g of green beans. lately I have been using PNG kimel Peaberry. I get to first crack at about 8mins and second around 12 mins.
            I dont have bean temps for this because at the moment Im only reading the air temp which is a lot higher.
            heres a pic of the results.
            • #21
              here are a few photos of my current roaster.
              Ive been very happy with it even though it was kind of thrown together.
              It used to sit over the little butane burner, but I had to crank it to get decent roast times.
              It now sits over the portable bbq in the last pic. this is much nicer, more heat, and Im not buying those little butane cans all the time
              • #22
                nice work, who is bending / rolling the SS for you?
                keep us updated on devlopments please
                • #23
                  Thanks,
                  I have hooked up with a friend of a friend who works at a steel fabrication place and is also into coffee.
                  for this prototype he said he is willing to have us there on the weekend to have use of his equipment and skills.
                  • #24
                    well if you can, make a template, but as it might be a "one off" that can be harder to do.
                    might be a few around interested if the price is fair i reckon
                    Leeham
                    • #25
                      Nice work, Matt. We have a similar setup but noise is an issue. How do you keep the noise down enough to hear 2nd crack?
                      • #26
                        That is my thought too.
                        It is very early days, but I do think there is a big hole in the market for a larger but cheaper roaster.
                        • #27
                          Originally posted by 6569606063636A737572060 link=1257649167/24#24 date=1257719421
                          What is it on your set up that is making the noise?
                          My current setup has no bearings so the metal on metal rubbing makes a bit of noise, but I can still hear the second crack loud and clear.
                          • #28
                            here is the drum for the new roaster with its wiper motor attached
                            with the bearing on the front it glides around very smoothly and quietly
                            • #29
                              templets will be made. Im hoping to make more than one. I already have two friends interested
                              • #30
                                Originally posted by 52767F7F7C7C4652766A7476190 link=1257649167/17#17 date=1257666128
                                I saw this bbq at bbqs galore, I was very tempted to buy it for my project but have since decided to have the whole thing made instead of altering something else.
                                very nice bbq though, all stainless.
