experiments in auto-power control for a Corretto
This is a sticky topic.
  • experiments in auto-power control for a Corretto
    Ive been experimenting with automatic power control for a HG+BM
    Corretto roaster. I wanted to be able to control the power from a
    computer so I could produce a consistent roasting profile. I also
    thought it would be fun to try and put it together :-)
    The first thing I tried was using X10 control switches. I talked to
    the people at smarthome.com.au, and they told me their switches could
    handle 10A, that they were based on solid-state switches and that they
    could be switched on and off quite quickly (several times per
    second). I thought that I could control the power level by switching
    on and off the HG via a X10 switch to give a percentage load. For
    example, to get 80% power Id switch it on for 0.8s then off for 0.2s.
    I bought some X10 gear, and tried it out. Unfortunately I found that
    while the HA103 could indeed do 10A, it would only switch quite slowly
    (best I could get was about one switch every 2s). The HA114 switches
    faster (about 5 times per second) but only does 5A. The loud clacking
    sound each time they switched also made it obvious that they used
    relays, which would probably wear out quite quickly.
    So I gave up on the X10 gear, and started looking for other ways to
    control the power. I asked an electrical engineering friend of mine
    (Paul Mackerras) and he thought Id need a custom circuit. He very
    kindly designed a circuit for me, and built a power control device.
    The device takes 240v in, and puts out a reduced amount of power
    controlled by a serial port. To use it, you attach to the serial port
    at 9600 baud and write the percentage power you want (so to get 80%
    you write "80%/\/n"). I bought a cheap USB serial adapter from eBay
    (just $3.87 including delivery!) and connected it to my laptop, giving
    me USB control over the power level.
    Pauls circuit works by using an opto-coupled triac with a PIC
    micro-controller. The PIC looks for the zero crossing of the AC and
    switches the power on based on a delay of a calculated number of
    milliseconds after the crossing. This allows it to very accurately
    deliver the amount of power requested (it has a little lookup table in
    the PIC which maps the percentage power to the timing of the on-off
    signals sent to the triac). Paul also set it up to monitor DTR, so it
    only switches on when DTR is set. This provides some additional safety
    that to ensure you dont switch on the power to the HG when you dont
    want to.
    Another friend (Hugh Blemings) has kindly drawn up the circuit
    using gschem (after my attempts were getting nowhere!), which should
    make it possible to produce a nice PCB layout for future versions. The
    prototype Paul built uses veroboard. Hughs circuit if available as a
    PDF and a raw gschem circuit here:
    http://samba.org/tridge/pyRoast/ppppd.pdf
    http://samba.org/tridge/pyRoast/ppppd.sch
    I wrote a little python app to control the whole thing.
    as you can see, it is heavily inspired by the CoffeeSnobs
    RoastMonitor java app, with the addition of some code to do automatic
    power control using a (slightly modified) PID control loop. It also
    has a little simulator built in which has been tuned to roughly match
    the roast profiles I get in my roaster. That makes it easier to play
    with the PID control without wasting a lot of beans :-)
    The code for the above is available at
    http://samba.org/tridge/pyRoast/ if anyone wants to take a look. It
    also contains a C prog (RawMeterReader.c) that can talk to the
    CoffeeSnobs DMM to read the temperature. It only works on Linux for
    now (Im running Ubuntu Karmic).
    The resulting setup looks like this:
    notice the little power control box in the foreground, and the pyRoast
    application running in the background. The two USB cables are for the
    power control and the link to the DMM.
    One problem I had initially was I kept melting the temperature
    probes. The solder in them melts at below 200 degrees, and the inside
    of the bread machine gets hotter than that, so the solder soon comes
    loose and you get very unreliable temperature readings. The problem
    was caused by initially having the temperature probe inside the bread
    machine, like this:
    This not only caused the probe to melt, it also meant that it could
    move around a fair bit while roasting. The solution was to put the
    probe into the side of the bread machine
    with it going through the wall of the machine as shown in the full
    setup picture above. It doesnt melt any more, and it is held much
    more firmly in place.
    Im still playing with the ideal roasting profiles for this setup, but
    the power control is working very well. It was also a lot of fun to
    build, and the coffee tastes great!
    Please note that you should only try to build the power control
    circuit if you have the right qualifications and you understand the
    circuit. Were thinking of submitting it to something like SiliconChip
    magazine in the future, and maybe someone will even make a kit, but
    meanwhile dont try it unless you really know what youre
    doing. Building 240v circuits (even ones that are opto-isolated) is
    not for beginners.
    Id also like to say a big thank you to CoffeeSnobs for all the ideas that
    went into the above. I wouldnt have tried to build this without seeing
    all the great results everyone else got with a Corretto roaster,
    and seeing the nice CS Java RoastMonitor app.
    Re: experiments in auto-power control for a Corretto
    author=646279747775100 link=1259627838/0#0 date=1259627838]Ive been experimenting with automatic power control for a HG+BM
    Bloody Ripper..  I would suggest you follow up with SiliconChip as I would like to see you get some brownie points for the effort you and ya mates have put into it..
    Will do some research as I can see that it could also assist in a mod to teh KKTO and add some level of technology to that system as well. Would be great to manage the heating... But the knockout would be to also be able to control the fan   ie. Dual output.. (Windows version is due when ?  )
    In particular... If the unit is made with the option of other uses..
    Well DONE.
      Wow, that is awesome, thats quite a talent you have there!, could you show us a roast profile of an actual roast? this could change everything..................again
      ;D
      Well DONE X 2
      warren
        Hi Guys,
        Did I hear right?
        Does Andy have a new version of his roast software in the pipeline, which may include control options?
        Lindsay
          he does have something in the pipline, he illuded to it in another thread, but this one is the OPs mod of teh CS Java software, cool hey!
            Hi Andrew
            Will you have nice roasted coffee from your Coretto in your room at the Linux Conf in Wellington? :-)
            I had tried to use a triac based clipsal light dimmer for better manual temperature for my GeneCafe but it kept tripping the Gene fuse. There are quite a few Clipsal light dimmers and some are for inductive and some for capacitive loads and think I used the wrong one so I gave up.
            I started a few weeks ago to write a Python gui using Qt for my roaster as Im using the older serial DMM. It would have also forced me to learn learn Qt4 over Tkinker :-) I like your Python program.
            (bugger though, Lenny only has python-kde3)
            Nice work to all of you on that circuit.
            Best wishes,
            Mike
              Hi Andrew
              Looks great!!
              I have a good mate whos an electronics engineer and could help me build one.
              What is the approx cost of the parts ? (excluding the DMM of course which I have)
              Im deciding whether to go your route or the Aurduino route - yours looks quite and elegant solution.
              Mokka
                Great stuff AT,
                I confess, I cant read the code [NFI] but I understand the electronics and have thought alot about this kind of control solution myself.
                Coupla questions:
                How does the HG behave under reduced cycle [eg 80%]?
                ie Do you notice a different sound, fan speed etc.
                Im just wondering as JavaB tried PID control of the HG element [not fan] some time back, and wasnt happy with the results [IIRC cool air blew over the beans when PID output was low]
                As your controller is not On/Off it should resolve that problem.
                Regarding your "look up table":
                1. Is the PIDs set point effectively "tracking" in accordance with the tabulated profile?
                2. Do you increase the sampling/calculation resoultion in the time between FC & SC...It strikes me that this will be the most critical and hardest to control period [due to the exothermic reaction]?
                How repeatable is a profile for a different bean mass or a different bean type [not that you would use the same profile for different beans]?
                Can you post some actual roast profiles?
                Temp control of an HG element will be pretty fast due to the low thermal mass, do you think your system will work with a higher thermal mass such as a Turbo Oven element?
                If it will work, using this controller in a "closed" system ala SCTO/KKTO would be about the perfect roasting solution.
                Cheers Reuben
                  Originally posted by 6077677061667760120 link=1259627839/7#7 date=1259715994
                  Great stuff AT,
                  Coupla questions:
                  Cheers Reuben
                  I have put a PID on my Coretto. But unlike Andrews contraption the PID controls a SSR. The SSR then switches the HG and the BM element.
                  The lag time on the element is about 30-60 seconds before I see a change in temperature gradient.
                  After a lot of roasts I find that I use the PID in a different way to I intended. I control the ramp to first crack manually, with the ability to switch the BM element off/on and the HG off/low/high.
                  The most common way I roast is to leave the element on and the HG low all the way to FC. If the roast is running slow I put the HG high for a few moments every 30 secs. Running too fast I use the PID to then slow the roast down.
                  The PID is then used to control between FC and SC. This where it is really, really useful. I can sit almost anywhere between FC and SC for however long I like.
                  The PID can also be used for "experimenting". I can run the roast quickly to a high temp before FC and use the PID to hold the temp so it doesnt run into FC too early. It aint perfect. It does over run but you learn how much it over runs, where and when to set it.
                  So I basically use it more like a brake. It allows me to control the roast more easily. It also picks up temperature changes before I can, more importantly the rate of temp change, very usefully to stop runaways.
                    Bassway,
                    I like the PID "brake" approach you describe and would be interested to hear more.
                    eg Is the Lag occuring because of the element [have you tried just the HG]?
                    Hint Hint: Perhaps you could start a new thread on your PIDd corretto application, as I think both of these topics deserve their own space
                      Hi Mike,
                      I looked a bit at light dimmers, but I couldnt find one that could
                      be computer controlled and would take 10 amps. Did you find a 10A
                      one? I think youd want one for a resistive load (as a heat gun is
                      really just a big resistor).
                      Cheers, Tridge
                        Hi Mokka,
                        Paul bought the parts, and I think it cost him a total of $86
                        (including the case and all the connectors), but he didnt really
                        attempt to find the cheapest suppliers. When he later looked up some
                        cheaper suppliers he thought it would probably be possible to do it
                        for around $60 or $70.
                        If you do build one, you will need the PIC program code to load
                        into the PIC (Ill put that one the website soon).
                        You also may want to hold off till next week, as we attached
                        the power controller to a CRO today, and noticed some strangeness
                        in the waveform when it was doing above about 90% of power. Paul
                        is going to look into it, and may change some of the component values
                        to ensure the triac stays happy over the full power range.
                        Cheers, Tridge
                          Hi Reuben.
                          It is fine at power levels of 80% or so. The place where it gets into
                          trouble is at much lower levels, say 20% or so. It seems to depend
                          on the heatgun. While roasting yesterday my Ryobi HG stopped
                          working completely when the power control was below 20%, and
                          I thought Id burned it out. It turned out that Id just tripped the
                          over-temperature sensor in it, and it came good again a bit
                          later. Paul and I suspect that what happens is that the fan cuts out
                          before the heating elements does, so the element gets too hot
                          if running at really low powers. Im thinking of adding a lower limit
                          to the power I put out in the python code to avoid this (ie. if
                          the control code decides to put out a power level below 25% then
                          just do 0%).
                          My Ozito HG seems less a bit less sensitive to this, so it seems to
                          depend on the model of HG.
                          Regarding the PID control, Im currently experimenting with
                          different PID values and methods of control. The key problem
                          is that PID control doesnt really take good account of a long
                          lag between applied heat and temperature change. Ive noticed
                          that the lag is of the order of 15s or so between when you raise
                          the power the and temperature starts its full ramp up. This means
                          that with normal PID control you get oscillation.
                          The python code has a built in simulator to make it easier to
                          try to tune the PID control, and it can also run with an speedup
                          multiplier, so you can watch a simulated roast at (for example)
                          50x speed, allowing you to see the effect of varying the PID
                          parameters.
                          To illustrate, here is a screenshot with a loaded profile from a real
                          roast (in blue) and a simulated run (in red).
                          This example shows quite a few interesting features. First off, the
                          little steps in the real profile every 2 minutes are because the BM
                          program reverses direction every 2 minutes, which sweeps some
                          "cold" beans over the thermocouple. I havent built that effect
                          into the simulator yet (alternatively I could hack the BM to not
                          do this!).
                          You can also see large oscillations in the real profile of about 5 degrees
                          once it gets close to its target temperature (in the above the target
                          profile for both the real and simulated roasts was set to a simple
                          flat 210 degrees). Both the simulated and real roasts used the same
                          PID control code (well, not strictly "PID", but a variant on the theme).
                          The good news is that the simulator is tracking the real roast fairly
                          well, which means the simulator is producing a somewhat reasonable
                          emulation of the behavior of the roaster. The bad news is that the
                          control code itself is doing a lousy job of converging on the target
                          temperature.
                          Ill play with the control code a bit more soon, and hopefully
                          will get something that produces a much smoother match
                          to the target with the simulator. Then Ill try it again with a
                          real roast and see if it matches what the simulator produces.
                          At the moment my simulator is based on a simple
                          "bucket brigade" system that slowly propagates heat
                          along a series of buckets, with the HG power applied
                          at one end of the series and the thermocouple readout
                          coming from the other end. That is basically a very crude
                          one-dimensional model of a roaster. If you are interested
                          in how it would react with different thermal masses
                          and other roasters then I suggest you play with the simulator
                          to try to match the characteristics of your roaster.
                          There is also lots of scope for making the simulator much
                          more accurate, as we have plenty of CPU power to play
                          with (one advantage of doing this on a laptop, rather than
                          on a system like an arduino). It appeals to the CS/physics
                          geek in me that I get to play with thermal simulations while
                          building a coffee roaster :-)
                          If you want to play with it, you dont need to build any of the
                          hardware to run pyRoast as a simulator. Just install the right
                          pyQt packages, and run it like this:
                           ./pyRoast.py --simulate --target=210 --speedup=50
                          Currently Linux only, though it should be possible to port to
                          windows if I replace the current KDE plot widget with something
                          based on PyQwt  (which works on windows).
                          Cheers, Tridge
                          2. Do you increase the sampling/calculation resoultion in the time between first crack & SC...It strikes me that this will be the most critical and hardest to control period [due to the exothermic reaction]?
                          Cheers Reuben
                            Hi again Reuben,
                            I neglected to answer all your Qs in the first reply.
                            yes, the sound of the HG varies noticeably as the power level
                            changes, changing in both pitch and volume. I think this
                            is just the fan changing speed.
                            yes, you can either load a full profile (with the --profile command
                            line option), in which case the power control code uses that profile
                            as the target, or you can use --target=NNN which is just shorthand
                            for a flat profile at a fixed temperature.
                            The control code Im playing with at the moment uses the slope
                            of the temperature curve (with some smoothing) to predict
                            the temperature at a point in the future (Ive been experimenting with
                            how far in the future, but 20s seems OK). It then uses the difference
                            between that predicted future temperature and the loaded profile (or
                            target) as the input to the control code.
                            no, the DMM gives temperature samples every 0.5s, and I just
                            do the control calculations at the same frequency, but using a
                            smoothed version of the DMM temperature output.
                            Ive only done a few real roasts with this setup so far, and Im really
                            just aiming to get the simulator right so I can then develop the control
                            code more using the simulator. That wastes a lot less beans, and
                            there is only so much coffee I can drink :-)
                            The few roasts I have done seem fairly repeatable, though of course
                            I keep playing with the control code, so most times I have different
                            control code than the last roast, and that can have a big impact
                            on the resulting temperature profile.
                            I dont see why it wouldnt work, as long as you adjust the control
                            parameters to match the roaster.
                            Cheers, Tridge
                              updated circuit
                              As I mentioned above, Paul and I found that the circuit gave a lousy
                              waveform at higher power levels when we looked at it with a CRO.
                              Paul has found the problem, and has modified the circuit to fix the
                              problem. The problem turned out to be in the zero-crossing
                              circuitry. If the PIC turns the power on soon after zero is crossed,
                              then then the triac would get too small an input, and strangely enough
                              would actually turn on later (and at a randomly varying time) than if
                              you wait to turn it on when there is enough power.
                              The fix for the circuit is here:
                               http://samba.org/tridge/pyRoast/fix-zc.png
                              Hugh is going to redo the circuit diagram to incorporate this change (I
                              dont know enough about circuit design to even work out where
                              the above change fits!). Hugh is also working on producing a PCB
                              layout for the circuit.
                              With the above change the CRO shows a really nice waveform at
                              all power levels, and Im getting more stable roast profiles.
                              Ive also made some improvements to the pyRoast.py code, although
                              the power control code still needs more work.
                              Cheers, Tridge
