KKTO Beta Testers Feedback....
  • KKTO Beta Testers Feedback....
    This thread is intended for use by the "KKTO Beta Testers" for the collation of all feedback, suggestions and recommendations.
    Not intended for general discussion about the KKTO where this thread.... http://coffeesnobs.com.au/YaBB.pl?num=1228631426/0#0 has already been established for that purpose.
    Thanks All....
    Re: KKTO Beta Testers Feedback....
    Initial minor faults:
    * One adaptor ring screw was bent; chance of this could be minimised by screwing all the way in or bagging separately.
    * Base has a flattened edge; it gives mine character but the cause needs to be eliminated.
    * One motor wire had come loose; maybe add wiring diagram to the instructions.
    * Cloth tape holding the wires down looks a bit tatty; maybe even a neater piece would suffice.
    Once Id worked out the adaptor ring was upside down and reconnected the wire, the test run with some green beans went well.
    Tomorrow Ill fire up the top to make sure its heating.
    First roast still to be scheduled.
      One of mine doesnt screw all the way in as the hole may be slightly lower or not threaded properly. You may need to ensure the TO is located exactly in the centre of the adapter ring and then tighten each screw incrementally. But the TO is still securely held.
      No, mine was loose too and I think this may be deliberate. As KK mentioned, you may need to check the rotation of the motor.
      I noticed that but it is underneath, not visible, so aesthetics isnt a concern. My concern is whether it will hold when the KKTO heats up.
      Some suggestions:
      1. Cut L-shaped slots on the pedestal for lugs or screws attached to the main pot to fit into so that it can be affixed to the pedestal (but also easily removed). Then you can pick up the entire KKTO by the handles, making it easier to carry.
      2. Have a two-piece shaft:  the main shaft remains attached to the motor and extends to almost the bottom of the inner chamber . The agitator has a short shaft with a keyed end that fits into the slotted head of the main shaft (see attached pic). Only the agitator comes away when you lift out the inner chamber for dumping and not the whole shaft. This will also reduce the chance of damage to the shaft as the inner chamber wont be resting on it and also make it easier to refit. Furthermore. you could use then use a smaller inner chamber for smaller roasts and add an extension piece to lengthen the shaft.
        Eventually it will be encased in heat sink or clips on the floor base
        Some suggestions:
        The angle of the lower portion of the pot is the problem
        As we are marrying different off the shelf items with precision made items its the best solution
        2. Have a two-piece shaft:the main shaft remains attached to the motor and extends to almost the bottom of the inner chamber . The agitator has a short shaft with a keyed end that fits into the slotted head of the main shaft (see attached pic). Only the agitator comes away when you lift out the inner chamber for dumping and not the whole shaft. This will also reduce the chance of damage to the shaft as the inner chamber wont be resting on it and also make it easier to refit. Furthermore. you could use then use a smaller inner chamber for smaller roasts and add an extension piece to lengthen the shaft.
        I wanted to do that as well but it would have cost 3 times more to make
        Similarly with the pot base, anything is possible at a cost
        I had to weigh up cost against function
        Larger production runs may bring costs down of a 2 piece agitator & purpose made roasting section
          Mine arrived!!! Yay.
          Agree with TG on the above have a bit of child caring to do and then I will be out to play (give a little get a little).
          A parts diagram too would be handing when putting it together so that there is no confusion, having said that I had no issues.
            Unless I overlooked something, there were two terminals on the motor gearbox.  One already had a wire attached and I didnt think a diagram would be necessary to work out where the other wire attached.
            But I agree that it wouldnt hurt to have some sort of colour coding on wire and terminals + a diagram to eliminate confusion.
            Originally posted by 684C454546467C684C504E4C230 link=1261484678/3#3 date=1261520748
            Definitely appreciate that. There are always tradeoffs.
            Lifting the KKTO out of the box yesterday, the first thing I noticed was that the pedestal didnt come out with it and subsequently trying to fit the main assembly back onto the pedestal was a little tricky and that was with a cold KKTO.
            I think having the shaft attached to the motor rather han the inner chamber is preferable from an ease of use perspective and worth the extra $s IMO.
              The wire that had come off for me was at the other end and I had two to choose from.
                Originally posted by 4C465344444B5F592A0 link=1261484678/5#5 date=1261532649
                Unless I overlooked something, there were two terminals on the motor gearbox.One already had a wire attached and I didnt think a diagram would be necessary to work out where the other wire attached.
                I could always solder them next time ;D
                  Ditto.
                  A closer inspection revealed which of the two terminals the wire had popped off from.
                    Would just like to raise a suggestion and KK can can it if he likes.....
                    If everyone can limit their feedback, to the KKTOs as supplied for the time being. Improvements, nice-to-haves, etc can be addressed later. At this stage I think we just want to make sure that the basic package has all specific issues addressed first before heading off in other directions...
                      I can see where you are coming from here Mal. We dont want to get sidelined into discussions/debates about the wiring, for example
                      But feedback is that: commentary about the product. Any feedback could be good feedback and I dont think it should exclude what we (beta testers) feel would improve the KKTO
                      e.g. this worked well but I think it would be better if...etc.
                      Anyway, KKs call. I meant to ask how we to present feedback - is it just posting into this thread or are you expecting a report or something?
                        Ill leave it to KK to answer your queries Steve but Im sure detailed reports wouldnt be knocked back.... in email or PM form back to KK.
                          Let me start off and compare the original Roaster Design & The New Design
                          Original design was conceived to be
                          A small roaster that can be easily stored away
                          Roast coffee to near shop quality standard
                          That did not have chaff fly around everywhere when roasting coffee
                          Can hear the cracks with relative ease
                          Can be tweaked to a coffee enthusiast’s content
                          Robust construction
                          Can be copied by others with handyman skills
                          However what needed to be improved was
                          Having to use oven gloves to remove the hot perforated bean basket
                          Agitator fell with the beans when dumped to cool
                          Having to pick up the whole roaster including base to empty the spent chaff
                          Separated from the base
                          Insulation
                          The new design utilizing the pasta pot set has addressed most items on my wish list and still true to the original design
                          The dual pot design allows one to use the pot handles to empty the roasted beans
                          The agitator is part of the roaster chamber and does not fall in with the roasted beans
                          The bottom pot can come off the base hub to easily empty its contents of collected chaff again by the handles
                          The insert fitted inside the lower pot is insulated at the bottom and double walled on the sides
                          Added a TO to pot adaptor ring
                          Volume is reduced & can be reduced more by removing the TO to pot adaptor & place the TO direct to the pot
                          Appearance of the design to be pleasing to the eye
                          It can still
                          Be tweaked to a coffee enthusiast’s content
                          Is of robust construction
                          Made it easier to make & affordable by offering it in kit form even when one has to drill ones own pots
                          Plus all the other positive attributes
                          Hope its simple operation will roast coffee that pleases your taste buds
                            I was under pressure to get the roaster to all of you before Christmas
                            I had to collect the components in 2 trips
                            Spent all weekend to assemble them for you free of charge (cos I am a nice guy  )
                            I compiled the user guide in the early hours of the morning
                            I had no time to take assembly photos as I wanted to
                            Then pack & despatch them on Monday
                            Followed by courtesy phone calls
                            Now I say this tongue in cheek  :P
                            And you comment about a loose wire   ;D
                            I actually had a little laugh when I read it and said to myself if they only knew what I went through
                            Now you know
                            At your service
                              No complaints here mate.... 8-)
