KKTO Beta Testers Feedback....
  • Re: KKTO Beta Testers Feedback....
    Originally posted by 60757C6C607B7B0F0 link=1261484678/176#176 date=1265841729
    Looks nice KK - when is the full production model with all the mods sorted coming out?  Any idea of cost of that yet?
    Just working on a couple of new "test" agitator blade designs
    and a guide tube for the drive shaft
    Info & details on this will be posted soon
    Originally posted by 696E7B6D6076503E3636360F0 link=1261484678/178#178 date=1265855729
    I think that 26 minutes is a long time for a 500g roast.
    And
    Originally posted by 4E61686A7D426E616E686A626A617B0F0 link=1261484678/179#179 date=1265864299
    At 26min I would be thinking my system has failed..Longest I got to was about 21min with nearly a kg of beans..
    I wonder if Alex means 26 minutes including the 9.15 min/sec on the stabilizing thaw setting
      Originally posted by 290D040407073D290D110F0D620 link=1261484678/180#180 date=1265871068
      Mate - are you considering 2 blades - one for smaller roasts and one for say 600-900grams (for eg).
        Yes to that question and also to prevent some smaller variety beans from wedging under the blade
        Green coffee beans can at times act as a wedge (much like a door wedge) due to there shape - flat on one side & round on the other
        I have ordered to be laser cut two blades one of each for testing
        1) Same shape as now but the inner portion removed
        2) A double (full diameter) paddle with the inside section laser cut out
        In theory it should work as the original agitator blade does
        1) It will create an easier path for the beans to travel while still mixing
        2) Eliminate pressure at the gap between the blade & the insert base
        3) the blade can be bent and shaped easier as required
        Here are the agitator blade drawings I got from the engineers
          very nice mate
            Spent some quality time with the roaster yesterday.
            I was still having trouble getting the blade low enough so as to not trap the beans without also scraping the bottom of the pot in parts.  I ended up grinding a little off the bottom of the agitator arm where it hit the pasta pot, but that did not help, so I raised the arm a little to allow beans to pass under and that actually seemed to work very well.  I was worried that the roast may be a little uneven if the beans passing under the agitator did not get mixed properly, but it appears to be probably the nicest roast I have done thus far.
            Pictured is 600gm of Nicuragua Cima del Cielo - 8 min stabilising at thaw, pulled at 19 mins, some time into R2C (CS10 - looks a little lighter in the photo though).  Prior to this I did another identical sized roast which I pulled at about 16mins, probably just a little too soon (CS8), but we shall see/taste.
            I also cut a couple more chaff slits (now 4 in total) which cleaned up the roast considerably - very happy.
            Overall I think I have been a bit tentative up until now when roasting as I am still having difficulty identifying the cracks, but this last roast has given me a lot more confidence
              Originally posted by 587F626860676E696A68600B0 link=1261484678/184#184 date=1266120386
              Overall I think I have been a bit tentative up until now when roasting as I am still having difficulty identifying the cracks, but this last roast has given me a lot more confidenceSmiley
              I was having the same problem. Then I got some good advice... RELAX! I was getting so worried about stuffing it up, the time etc that I wasnt making it to RSC because I was pulling too early! I got a great roast out of it the other day (while relaxing) and heard the different cracks and stages a lot better this time.
                I think I may have said that ;D I say it to my wife as well... But she does not listen
                  Originally posted by 163B322F03383A570 link=1261484678/175#175 date=1265528410
                  I pulled the roast just into second crack (again I think) at 26:00 when I cooled it between two colanders over a fan.
                  Originally posted by 1C3831313232081C38243A38570 link=1261484678/180#180 date=1265871068
                  fatboy wrote on 11. Feb 2010 at 13:35:
                  And
                  AngerManagement wrote on 11. Feb 2010 at 15:58:
                  I wonder if Alex means 26 minutes including the 9.15 min/secon the stabilizing thaw setting
                  Youre much more than just a pretty face KK,
                  I incorrectly transcribed my notes above - my notebook has from T0 being the from the start of the thaw whereas above I had T0 being the start of the roast then I switched for when I pulled them.
                  I did pull them at 26.00 from the start of the thaw or 14.45 from the start of the roast.
                  I agree WSully, I probably did pull it before Second Crack, but Ive been reading a few things about a trying lighter roasts to bring out the bean characteristics.
                  Sorry for the confusion.
                  Alex
                    It was a gut feeling
                    You were fortunate to have a person to person roaster lesson
                    All while having a relaxing coffee during the roast ;D
                    We had a great afternoon
                      More roaster testing
                      Originally posted by 00273A30383F3631323038530 link=1261484678/184#184 date=1266120386
                      A recurring observation is posted by many Beta Testers. That of identifying the bean cracks
                      I recorded the first & second cracks on a digital hand held recorder
                      I will attempt to convert the files to WAV and post the recordings if I am able to ?
                      I also did 3 roasts today to try out this blend posted by smokeydeck http://coffeesnobs.com.au/YaBB.pl?num=1265340351
                      Compilation photo
                      Pic #1 500gr of Brazil Alterosa
                      Pic #2 500gr of Kenya Ritti AA
                      Pic #3 500 gr of Ethiopian Harrar
                      Pic #4 chaff collected from the last roast
                        I had to zip the WAV files
                        1st Crack
                        2nd Crack
                        You may also hear my love birds in the background
                          Mmmm....
                          Mine sounds nothing like that KK in fact, I cant hear anything above the noise of the agitator motor whine :-?
                            Yup, Im with Mal - mine sounds nothing like this. Is this recorded in or outside the roaster? I definitnely hear much better cracks when I burp the roaster......
                            I have tried using an old stethoscope to listen too, but there is too much mechanical nosie transmitted through the metal or glass to be useful :-?
                              Originally posted by 6F42464A472B0 link=1261484678/191#191 date=1266413529
                              Mmmm....
                              Originally posted by 785F424840474E494A48402B0 link=1261484678/192#192 date=1266414028
                              Recording
                              First Crack is outside from start to finish
                              Second crack is outside for the first 3-4 seconds and then removed the TO
                                For some time now I have been working on a different agitator blade design
                                Similar in design to a commercial cooler and some recently posted by other Coffee Snobs members with a KKTO design
                                The main stumbling block is the side thrust of the drive shaft
                                I have made a centring bush/bracket  design (prototype) that can be retrofitted to the current units & included in the kit on future units
                                This will hopefully facilitate a diverse number of new blade designs so they can be used with fixed or floating drive shaft configurations and motors
                                It is secured inside the perforated roasting chamber on the sides
                                A centre bush fits over the drive shaft holding it firmly in place acting as a guide
                                So onward we go
                                I also hope that with different blade designs the agitation will be quieter and provide less stress on the motor
                                So all can hear the cracks a little better
                                The photos are a mock up of the idea
