Re: First Roaster, what to buy...
I have the Behmor but not the KKTO.
The Behmor is a great, no fuss, very little mess option.
Plenty of tweaking is available via the profiles along with bean mass adjustments.
These things are very new (a week old for us CSrs) so plenty more info will come in time.
Note that with either option I feel you need an external cooling apparatus.
The KKTO appears to do a larger roast so if that is needed, there is your deal clincher. Other than that I cant see much in it.
I have both Behmor and Turbo roasters they both do a fantastic job with in there meansOriginally posted by 104F57414A414D444447474F434C220 link=1263027599/7#7 date=1263079865Can anyone explain the roasting process with both the KKTO and Behmor.Mal mentioned that the KKTO is more "manual" but in what way?
Huh I googled Behmor user manual and got it on the 2nd hit Roll Eyes
Have you thought of having a read over KKs thread which will explain comprehensively how his roaster works. Use the search tab on the term KKTO and lo and behold you will find that thread too- its just like magic!
A little effort wont hurt you that much- I promise you.Roll Eyes
It just depends on what amount of beans you want to roast as mentioned the KKTO can roast 900gm + against the behmors 500max. they both have a learning curve which is the fun in home roasting and you end up fresh coffee that is great in the cup :P
There is plenty of information posted in KKTOs Beta and his pre build section and some of us are posting our results on the Behmor, As I have said they are both great to work with but the choice is all yours at the end of the day.. ;D ;D
Cheers Gra..
:-? I googled Behmor user manual and got it on the 2nd hit :Originally posted by 4F6260666B6A6E030 link=1263027599/5#5 date=1263078352Can anyone explain the roasting process with both the KKTO and Behmor. Mal mentioned that the KKTO is more "manual" but in what way?
Have you thought of having a read over KKs thread which will explain comprehensively how his roaster works. Use the search tab on the term KKTO and lo and behold you will find that thread too- just like magic!
A little effort at CS is always rewarded with results....
I cant comment on chaff and the Behmor but it shouldnt be a problem with the KKTO the way its designed.
Thanks Mal, it does help in away because at least I know both are up to the job.
Are spare parts availiable for the Behmor?
I also read somewhere that chaffy beans are not advices in the Behmor? Does the KKTO have this limitation?
Sorry, questions, questions but there are threads about the Behmor where everyone raves about it, and threads about the KKTO where everyone raves about it which doesnt make my choice any easier.
Would anyone like to create a Pros and Cons list for both that a newbie roaster can use?????
Probably comes down to the batch size you prefer to roast too Id say...
The KKTO can roast successfully with batch sizes up to 900g, with careful attention paid to technique where-as the Behmor is rated as a 1lb/500g maximum batch size. Still a pretty decent batch size for a home roaster though and with more control input possible by the operator.
Doesnt really worry me either way, as I quite enjoy the manual input required by a KKTO style roaster and 750g is my preferred batch size which is readily accommodated. The Behmor is a nice looking unit it must be said and the results in the cup are quite decent too. Probably not much help to you in the end mate, sorry about that.... :
Saw that, pity its in Melbourne and ACGs prefers a pickup.
and to confuse you even more, there is a Gene for $500 over here
http://coffeesnobs.com.au/YaBB.pl?num=1263025234/1#1
Neither has been around long enough to do a real side by side work up..Originally posted by 7C51535558595D300 link=1263027599/0#0 date=1263027599The Mrs has given the go ahead for a roaster and I was all set to go for a KKTO until I did a bit of reading... and now I dont know what to buy. Still leaning towards the KKTO though.
Does anyone have any thoughts or advice about how I should start out.
Ive looked at the Behmor @ CS. Doesnt seem to have much control built in, or is that a good thing?
The KKTO, does a decent batch size, can fit under the BBQ, and I think its pretty clean during roasting too from the posts Ive read.
Thought about a popper, cheap, small batches might be restrictive.
FYI budget is maxed out at the $500 mark, must be able to be tidied away so the mrs doesnt trip over it.
If this sorta post has been done a 1000 times Im sorry, did search but couldnt find anyone comparing the Behmor and KKTO or anything else that fits in my budget.
I was tossing up as to a KKTO kit and also a Behmor ... The wife would have my guts for garters in about 10sec.
As I all ready have a Early version KKTO and it works well.
My gut feel is that the Behmor has some smarts built in and some smoke control... Plus it looks smart and will fit easily in the kitchen and on the stove top (under the exhaust hood)... Plus a great buy..
The KKTO is a bit more manual, and for some beans... On teh stove (under the exhaust hood) maybe; but for me it works well and on the deck...
If ya can... Get an invite to go and have a look at both units... Then make ya call..
If this sorta post has been done a 1000 times Im sorry, did search but couldnt find anyone comparing the Behmor and KKTO or anything else that fits in my budget.Tags: None
