Heat Guns
  • Heat Guns
    I also use the $40 Ozito. Its a good price for a variable temp gun and has a 3 yr warranty!
    Re: Heat Guns
    3 year warranty sounds pretty good ....... keep your reciept.
    what watts do they run, or max/min temps
    cheers
    hotshod
      Re: Heat Guns
      Im looking for a heatgun now that Ive scored an old bread maker from freecycle. Did you get the ozito from bunnings?
        Re: Heat Guns
        I use a digital Bosch but yep, Ozito is now a Bunnings brand
        Steve
          Re: Heat Guns
          Ive had my variable temp Ozito for a while now with no issues. However, the temperature adjustment is definitely non-linear and I am also finding that I am having to use a higher setting these days to achieve the same temperature in the pan (using the same bean mass). As such, I am seeing an increase in the amount of tipping.
          If you have the $$, get the Bosch.
            Re: Heat Guns
            Quote: "If you have the $$, get the Bosch." unquote
            I concur on the Bosch or in my case a Makita 3 fan speed variable temp gun, the beauty of these guns is that they can be set up in one position and only have to adjust the fan/temp as required it makes roasting so much easier and with Andys roast monitor software repeating a roast profile is not a problem.
              Re: Heat Guns
              After much searching around and talking to Tradies who use them to make a living (Professional House Painters mostly), Ive just tracked down and bought a new "Metabo 2,000W Model #HE2000".
              The Tradies who use them, swear by em for longevity, ruggedness and reliability. Good enough for me and they reckon it will be a doddle to use one with a Corretto (I owe a couple of bags of fresh coffee now ;D).
              Heres a picture of one....
                Re: Heat Guns
                Im with mal on this one, i was(still am i suppose)a tradie(resilient floorcoverings aka timber/comm vinyl/carpet etc) and i used heat guns flat out bending commercial vinyl up walls and around corners, i went through tonnes of heat guns, metabo was by far the best and longest performer.....by far, and they never blew up(literally) like the rest they just lost heat......which is handy when its held in your hand!
                So are you roasting with both the corretto and the KKTO mal ;D
                  Re: Heat Guns
                  Gday Warren....
                  Always a good idea to ask people who use hardware every day making a living, I reckon, when it comes to buying something for the long haul.... 8-)
                  As it happens, Im really struggling with the KKTO. Havent been able to get a decent roast out of it, easily, since the couple of roasts that KK "supervised" while he was here. So, Ive gone back to the Corretto.... Im going to carry out a couple of simple mods with my setup using the Metabo to make it even easier for me to use and then stick with that for the time being.
                  As time progresses, perhaps updates to the KKTO will make that a viable option for me to use but as things stand now, Im not prepared to sacrifice any more beans towards an unknown outcome. When it comes to roasting coffee, Im a very tactile sort of bloke and just feel too far removed from the process with the KKTO (for now). Will wait and see how things work out I guess.... :-?
                    Re: Heat Guns
                    Know what you mean Mal - if only I could get in the drum! ;D
                      Re: Heat Guns
                      Its a bit like that, isnt it Den.... ;D
                        Re: Heat Guns
                        Well nit yourself a Insulbrite jacket with a hoodie and some trackies and boots and jump on in! you may want some motion sickness tablets too
