Re: Another KKTO on the cheap
Well, having looked at Warrens system and doing a bit of thinking, I realised that one of the defects of device was that the agitator was too rigid, hence the jamming when beans caught between between the agitator and the pot wall or bottom. I have therefore rebuilt it, with the member which runs close to the wall hinged and arranged so the "ploughshare" effect pushes it out, but it can swing inward if obstructed on the outside. The opposite vertical strut is attached with fairly light aluminium sheet, and the centre component is of the same sheet.
The effect is that the motor may now load down, but doesnt stall. I even have some video showing beans being catapulted around the pot before I tweaked the settings to reduce the risk of jamming. In the video linked, you can see that the motor slows at times, but keeps running. This is with a 300 gram load.
http://www.youtube.com/watch?v=gWti9utM5-s
I have done one roast, and I think the results look more uniform than earlier. I found I could easily tell the differences in my earlier roasts between beans roasted to the beginning of second crack and those done into rolling second crack. So Ill be interested to try these in a few days time.
.......anyway I digress. I called KK and what he told me (and I assume it relates to your TO roaster as well) was that the "sweet spot" for these roasters is 450-500g when it will almost look after itself. Smaller quantities can be done but require closer vigilance.
