Questions for Commercial Roasters in the know
  • Questions for Commercial Roasters in the know
    Hey guys,
    This is mainly aimed at those who own and use commercial roasters, im looking for a detailed description from those who know.....from experience so to ensure the thread gets seen , id appreciate holding out on the banter for a bit.....cheers guys
    Ive seen the process quite a few times now, i just have a limited knowledge of what is actually happening as far as exhaust settings, airflow v power/gas levels etc, and how they impact on each other.
    Is heat generally under the drum? or is it piped through with fans?
    Are most commercial drums solid or perforated?
    Mechanically, how does the load and dump of the beans actually work, i know there are 2 doors into the drum, but with a rotating drum......how does it work?
    Ive been hunting around the net for a simple diagram of a roaster with airflow and component details......do you think i can find one!
    You may have guessed that i have a vision of building a homemade gas roaster, itll be a while off, but i wouldnt mind tinkering with some designs/ideas on paper in the meantime.....looking to roast at least 1.3kg green....
    Thanks in advance anyone who helps and offers advice stay tuned! 8-)
    cheers
    warren
    Re: Questions for Commercial Roasters in the know
    Originally posted by 0004223B3B3E213639570 link=1269456311/0#0 date=1269456311
    Hey guys...
    1) Is heat generally under the drum? or
    2) is it piped through with fans?
    3) Are most commercial drums solid or perforated?
    4) Mechanically, how does the load and dump of the beans actually work, i know there are 2 doors into the drum, but with a rotating drum......how does it work?
    cheers
    warren
    Depends on type , design, age, brand , size of drum batch roaster involved but generally.....
    1) yes but not always (eg some machines have combustion chamber at side). Note some machines have burners directly heating the drum, others have a separate combustion chamber, but all mostly underneath.
    2) yes. "exhaust" fan at top of roaster pulls the hot air through...works like an "extractor".
    3) solid
    4) from the front "face" of the drum. At the front end, the drum is "open". That is, the drum is not a completely enclosed cylinder, it is kind of like a garbage bin. The open end is the front end. So when you open the door at the bottom of the front the roasted beans come out, and when you open the door at the top of the front the green beens fall in. Dont open them both at the same time
    Am sure if Ive not explained correctly someone else will chime in.
    Regardz,
    Attilio.
      ahhh that is awesome attilio!, very interesting about the more modern roasters heating method! WOW
      and the face of the drum now seems obvious.......makes perfect sence
      all great info, thanks a million.....
      Anyone got any experience in attempting to build this type of home roaster? any tips from the pros?
      Thanks heaps guys, the more info the better
      PS does anyone have any of the pictures i was talking about above?
        PPS, if anyone is thinking of carrying out a simular project and has questions feel free to jump in and ask the brains trust(pros), that way anything i forget to ask wont be missed ;D
          PS. When ya dropping off ya TO ?
          Ya can then have a look at the old gas fired 2kg roaster I have out back... Intended use is that of a pot plant stand..
            Just in addition to Atillios reply, a number of roasters employ a perforations at the back of the drum to optimise airflow.
            http://www.probatburns.com/images/probatone_diagram.jpg
            Originally posted by 16223523380F133F36363535500 link=1269456311/1#1 date=1269472410
            Done this more than once. :-[ ;D
              1st Thanks Warren
              2nd i have a question that might help a build
              how do the beans come out once roasted?
              Is the drum of a commercial roaster level and the stirrers push it out or is the drum tilted a bit and they "fall" out?
              Leeham
                the drum is level and the paddles direct it outwards when the door is opened.
                  This is a diagram of a Probat Probatone (solid drum)
                    Originally posted by 043027312A1D012D24242727420 link=1269456311/7#7 date=1269479352
                    Think in the lines of
                    The Archimedes-screw
                    http://www.google.com/imgres?imgurl=http://upload.wikimedia.org/wikipedia/commons/a/a1/Archimedes-screw_one-screw-threads_with-ball_3D-view_animated.gif&imgrefurl=http://commons.wikimedia.org/wiki/File:Archimedes-screw_one-screw-threads_with-ball_3D-view_animated.gif&h=365&w=505&sz=3560&tbnid=HRBcZW WBKIINdM:&tbnh=94&tbnw=130&prev=/images%3Fq%3DThe%2BArchimedes%2BScrew&hl=en&usg=__ 1ujMs9srITt7WBA_vHriRCUFMSU=&ei=sMiqS770A4ugkQXmk_ nGBA&sa=X&oi=image_result&resnum=3&ct=image&ved=0C AwQ9QEwAg
                      Is there like a baffle type thing to prevent direct heating to one spot of the drum for to long, like to try and spread the heat of the burners more? I too am trying to build a drum roaster looking at about the 1-2 kilo range.
                        Warren,
                        I reckon you should give Roger from Supreme Roasters a call. If youre super nice to him he might let you come around to poke and prod his new 15kg roaster (I hope Im not speaking out of school here). And hes not too far from you either.
                        Hes passionate enough and probably keen to share his enthusiasm.
                          Uhm, the drum rotates. Stopping the rotation while the drum is hot would not be a good idea.
                          Not trying to rain on anyones parade, but a lot of these questions have been asked and answered previously.
                          There is no reason why someone cant build their own roaster though its doubtful you will get it right the first time unless you have a blueprint of a commercial roaster available.
                          The drum is of a particular length and diameter to suit a number of variables, eg. capacity, burner configuration, etc. The baffles are designed to move the coffee forward at a certain rate. The drum itself rotates at a determined speed that will create a wave effect ie. too fast and the coffee will be plastered up against the wall of the drum, while too slow and the beans will remain in continuous contact with the drum and slide.
                          Fans that pull too much air through the drum, I think are detrimental rather than beneficial; how thick, and what material you use will have an effect on the outcome, and the list goes on and on.
                          If I were wanting to have a 2kg roaster, Id pay the asking price of something commercial and proven, or content myself with something like fatboys bbq roaster setup.
                          Either way, I reckon you get what you pay for.
                            Originally posted by 283E3B3B2A28242D2D2E2E4B0 link=1269456311/12#12 date=1269492354
                            Every question in the world has been asked before dennis ;D its just not easy to get ALL the answers i was after
                            Unfortunatly the money i have is well and truly tied up in property, 5k is not justifiable at the moment, plus im a tinker...er and i love to play and whether it works or not, ill have a ball trying, i 100% understand what your saying, the ppl designing these commercial roaster have been trying, testing and perfecting for scores of years......im just a noob :
                            Always true dennis, i understand that......cheers heaps for your input, i really appreciate it
                            regards
                            warren
                              Hi Warren,
                              "No Im Spartacus... I mean also planning a drum roaster build..."
                              Youll find heaps of useful threads over on homeroasters.org - many clever people have succeeded in what the rest of us are aiming for!
                              Just to add to the replies above regarding Q.4 (how the vanes work). I asked the same question somewhere on HR.org and got my head around it from the responses. Like Attilio said, the drum is level, and the vanes are angled to push the beans forward. Because of this, the beans become more piled up towards the front door than the other end. BUT some roasters have a second set of axial vanes - attached to the axle of the drum rather than the walls - which pull beans away from the door. Axial vanes only scoops up beans from the top of the pile, so when the door is opened, the axial vanes no longer reach the beans and the beans can all be scooped out by the normal vanes.
                              I hope that made sense. If not - Dennis has a picture of a Diedrich drum which hes posted before I believe? It shows the axial vanes nicely.
                              Also, regarding Q.1 (wheres the heat?), both the Diedrich and Probat websites have some decent info on how theyre fired. Diedrich IR-series use a very indirect heating method whereas Probat and many others are directly-fired. Ive heard people say that its almost impossible to get scorching on a Diedrich (though Im sure its an exaggeration) - Ive also heard people say that you need the extra guts of the direct-fired types to have "real" control... so there are pros and cons, Im sure.
                              Im not really in the know, but I thought Id add what Ive found out so far.
                              Stu.
