hg with variable temp readout
  • hg with variable temp readout
    check this one out
    Re: hg with variable temp readout
    LCD does not mean it is a better HG.."variable temp"..... Would hope it was not fixed
    And get two or three side by side and they will not read the same..
    You want a quality HG that has stable and controllable Heat and if possible air flow..
    Mine does; but would not waist it on coffee beans That is what a cheep TO does.
      Ive been using a Bosch PHG 630 DCE with great success over the past 6 months or so http://www.bosch-presse.de/TBWebDB/en-US/PressText.cfm?CFID=1705465&CFTOKEN=a128df0c3ad1a1f d-C70D0198-E76B-5BBC-8C0E3E8AEC157D90&id=1429
      Very good heat control and variable air flow.
      No temp stability problems, it just does exactly whats needed.
      Bosch have had them in their range since 2003 so they must be a reliable unit, had mine for about 6 years and has done heaps of work stripping paint before it assumed its present role.
        very good heat control and variable air flow.
        It is a BOSH... Would expect nothing else..
        My old BOSH drill still out performs all teh new ones.. But after 10 years teh batteries are not holding charge as well as they could..
          Originally posted by 08272E2C3B042827282E2C242C273D490 link=1277256832/3#3 date=1277263882
          Ive got a Bosch electric drill thats over 30 years old and has been well used, replaced the power cord once and it still runs like a clock, mind you the Makita cordless is the go to drill nowadays.
            ok ill consider all these and any more comments about heat gun recommendations.
            thankyou
              Yep.....
              Metabo, Makita, Milwaukee, DeWalt for example, all make trade quality tools and worth a look. Ive gone with a Metabo HG as personal experience with this manufacturer over the years has been excellent in both home use and industrial use.....
                Originally posted by 2D36373C3C590 link=1277256832/5#5 date=1277269010
                ok iill consider all these and any more comments about heat gun recommendations.
                thankyou
                Hi tonee,
                Im holding out on Bunnings or Aldi doing the right thing leading up to Fathers day with a $20 2000W HG.
                I would be happy with a basic 2000W unit and 12 month warranty.
                Lindsay
