Re: FZ-RR 700 Baby Roaster
I picked up my baby roaster on Saturday and did 2 roasts. Im a complete novice to drum roasting with gas, relying purely on what Ive learned about roasting from using the popper and Corretto over the past few years.
So Im posting this so I/we can all learn from each others experiences with this baby...
First, I gotta say how much fun it is to use, and so simple. Im using my existing dual 8mj burner camp stove hooked up to a 4kg gas bottle.
I put 200g of Peru beans in, turned on the burner to full for a sacrificial drum seasoning roast. Got a fair bit of smoke as the chaff was coming off. Took the drum off a few times and opened it up to let some of the chaff out. Lots of sweet aromas on opening the drum each time, very nice.
Looking inside the drum I noticed the beans were not roasting evenly. First crack happened about 9mins at which point I turned the burner to low and then off completely at rolling first crack about a minute later. I pulled the roast at around 11 mins as the beans looked about right. Tipped into the vac cooler. Never reached 2nd crack.
As I said, quite an uneven roast, see pic Peru Roast 1. Most beans had black burn spots on them. Overall not a very dark roast. The Peru roasts really evenly in the Corretto and Gene. Post roast weight came in at 170g, 15% weight loss.
I was tempted to toss the beans, but I was so curious to find out what they tasted like. So I cupped it and [smiley=shocked.gif]... it was sweeter and smoother than the other methods used to roast thats for sure, and right after roasting. I was shocked!
No grassiness, the acidity was mild and smooth. Loads of body. The shot poured really well as has been mentioned here before. It seems Im getting more coffee from the shots ie theyre not blonding till much much later, they just seem to be brown for longer. Dont understand why though, more solubles perhaps than air roasting? Not sure, but Im happy to get more coffee. I did get some bubbles on the crema though.
Yesterday I got better shots and more sweetness, the bubbles in the crema were not there either. Again getting more coffee than roasts done in the Corretto or Gene. Dont take this as a direct Baby Roaster v Gene/Corretto, please. Its just my observation pulling shots from the same bean roasted in all 3 methods.
I then did the 2nd roast on Saturday. 200g greens again. This time I fired up the burner on a med-low heat to ease into the roast and try and get a more even roast and less burnt beans. After 5 mins on med-low I cranked up the heat till the first snaps of first crack were heard then immediately turned the burners down to low and then off again just as rolling first started. Pulled at approx 12-13mins.Post roast weight 166g, 17% weight loss.
The roast was a little more even, but darker. So its obvious that theres not enough agitation of the beans going on. I didnt cup these ones, I was just keen to get a better roast than the first.
I then did a 3rd roast on Sunday, 200g of Peru again, this time taking the drum off at 1-2 min intervals and giving it a good shake. Again ended up with quite an uneven roast and some black/burnt beans.
I havent cupped the 2nd and 3rd roasts yet, as Ive got some of the Peru thats come of age roasting in the Gene.
So, now Im thinking of putting in a small baffle or two in there to help with agitation as it seems the beans are merely sliding in the drum as opposed to tumbling in the drum. To confirm this is happening, I put 2 different amounts of greens into the drum and turned just the roaster on without the burner to see whats going on:
1. With 150g greens the drum just slipped around under the beans with no tumbling action
2. With 200g beans I got some tumbling beans but still the drum just slipped under the beans
I guess this explains the burnt spots on the beans and the burnt beans.
Before any mods are undertaken...dads keen as his a retired metal worker...
Im interested in some feedback from other baby roaster users and how their roasts are turning out, and see what you are doing.
I just cant stop the feeling of wanting to get out there and keep trying, I just wish there were more hours in the day to do so!
Ive attached pics of the first 2 roasts, taken without flash with the sun to my side.
Enough from me, at least for the moment ;D
Javabeen.
Javabeen.
thats the Prota type of the new TO Corretto ;D ;D ;D ;D
