Motors in Breadmakers?
  • Motors in Breadmakers?
    Hi,
    What sort of motors do most breadmakers use?
    Voltage?
    Current draw?
    Im planning to strip a BM down and use the parts for a custom made roaster.
    Re: Motors in Breadmakers?
    Capacitor Start/Run
    240V AC
    50Hz
    300W and up
    How are you planning to use the motor gc?
      I havent decided exactly what my new roaster will be but Im thinking something like a large scale version of a hot air popper. The BM motor would be used to agitate beans.
        Rightio gc....
        Please ensure that you have your completed "Fluid Bed" Roaster inspected and tested by a Licensed Sparky before plugging in and powering up, wont you? Wed hate to have one of our fellow CSers injured, or even worse....
          Hi GC,
          Ive cooked 2 BM motors to date, so currently use a 12v PC fan to cool my BM motors.
          For a custom stirrer, I think that unless you have OK gearing for your stirrer paddle if not optimum or you have a variable speed gear box or similar, then I would try a 12VDC windscreen wiper motor which should be more easily speed regulated.
          Also 12VDC is not the dangerous monster 230VAC can be.
          Just a thought
          Lindsay
            I have been using a BM motor for my KK Turbo roaster for 18 months no wories but thats the hole base with belt drive..As Mal said make sure that you have a sparkie wire and test...
            Cheers Gra..
              Originally posted by 714457360 link=1289711734/5#5 date=1289736619
              I have been using a BM motor for my KK Turbo roaster for 18 months no wories but thats the hole base with belt drive..As Mal said make sure that you have a sparkie wire and test... Wink Wink
              Cheers Gra..
              Adding to the above
              A KKTO was conceived to be used with 2 heat sources (1) Turbo Oven & (2) Heat gun
              The base hub can be inverted and many different small 12V motors can be used
              So it can be a basis or starting point for many designs for which I have 20 + versions
                Ok thanks for the comments and suggestions.
                I thought the BM motor might have been DC so I prob wont use it.
                I like the fluid bed idea but will need an agitator as the HG wont provide enough air volume.
                Id head down the Corretto path but Id like a more elegant looking setup. Also Id prefer to be able to cool the beans in the roaster.
                  Have a look at Oatley Electronics out of Perth for a source of DC motors and controllers.
                  Either that or get hold of an old R/C car and strip it of some parts might work for you. The 540 Mabuschi can size (used in these) is good for around 200W of good life at 10-12 V
                    I already have a small geared DC motor i can probably use. Im just wondering how it will handle the heat.
                      Extend the shaft and place something non heat conducting between the gearhead and oven area/agitator blade.
                      There is some pics around somewhere I will see what I can turn up
                        The use of a 12-24V DC motor seconded from a windscreen-wiper mechanism (or similar) would certainly be a much safer way to go, with the added bonus of almost infinite speed/torque control (depending on the controller used) - Ideal for a prototypical design... 8-)
                          Originally posted by 3C3B3F303832273730395E0 link=1289711734/10#10 date=1289794012
                          Thanks, some pics would be handy
                            Originally posted by 5C495E5E55585A495F525C5A553B0 link=1289711734/12#12 date=1289821261
                            Pretty sure Ive seen someone use a length of 12-13mm O.D. Bamboo for this purpose with a suitable drive socket/shaft fixed to either end. Reckon that would work pretty well....
                              Thats the one I was thinking of, couldnt find a pic. Using a socket (attach the agitator to this) and socket drive extension as part of your design makes for easier removal of the roast chamber.
