For anyone else who is silly enough to try and disassemble the TO...
(the usual disclaimer, I dont recommend you fiddle with 240V equipment. Or at least unplug it from the outlet first)
I had a peek through the plastic slits and could see what looked like a lunar landscape inside.... Mounds of sticky grey dust, almost like a hairy fungus covering everything. This stuff was even surviving a vac from the outside, after each roast.
Anyway, I removed fan #1, and soaked and scrubbed in cafetto, then took the element / glass & cover off to clean inside. The nut that holds the fan on is a reverse thread btw. There are three screws around the perimeter, about an inch long, that hold the glass, element etc.
Once inside, more of the same crud was cleaned out, and the inner fan was dark brown, with the centre black. More soaking and scrubbing.
I put it all back together, remembering that the inner fan sits under the spacer & mounts upside down, and the shaft for the (element relay?) has to be aligned with the temp control.
Now everything is back together & sparkling clean, and strangely enough it still works!
