1st time roaster, Recommendations on Pop corn popper machine
    Re: 1st time roaster, Recommendations on Pop corn popper machine
    Originally posted by 4E464F415656514D230 link=1294049376/12#12 date=1300797179
    I havent modded the popper in any way, what is the best way to drop the temp on the popper to slow down the roasting times?
    Firstly make sure more cool air can get in. The usual entry point is underneath.
    Remove the bottom cover and enlarge the holes in the bottom.
    Secondly, let more hot air out by drilling / cutting large holes in the upper body. This is best done by taking the top off so you can see what youre doing to avoid drilling holes in something you shouldnt.
    Originally posted by 585059574040475B350 link=1294049376/14#14 date=1300797824
    thanks java, unless I am blind it doesnt mention anything about modding the popper?
    I think you may need to get your eyes checked mate.... :P
    I just had a quick scan through the above thread to refresh my memory on its contents and there are loads of posts with very useful popper mods, from the very simple to the outright FrankenPopper category.
    You can always use the Search Tool if youre chasing more specific info though....
  • melbuurn
  • Javaphile
    Have a read here: http://coffeesnobs.com.au/YaBB.pl?num=1174699442
    Java "Mods R Us" phile
  • melbuurn
    ive tried several roasts, had massive fans pointing at the popper, done them at 6 in the morning yet it is always too hot. First crack happens at about 3 minutes, second just after 4 and an oil slick at about 4:30
  • chronofields
    Hey guys heres some photos of my first attempt! Using Mysore nuts coffee beans haha.
    P.S. Yea :P since im using the machine outside... I basically dont have any problems with chaff it all just blows away
    Originally posted by 474055434E587E10181818210 link=1294049376/9#9 date=1294110832
    the Behmor would be even better with the added benefit of actually being rated for AU power supply.
    And capacity of more than 120g. :P
  • fatboy_1999
    Originally posted by 676C766B6A6B626D61686077040 link=1294049376/8#8 date=1294109026
    Well...99% of poppers dont have a way to capture chaff
    That would be the tarted up section.
    I still think youd be better off with a $12 popper with the popperdom sock mod for catching chaff. I cannot find the post at present (it was very old) but it was some sort of light mesh that slipped over the popper once the roast commenced and allowed air to pass through whilst catching the chaff. Was about $5 from memory.
    Of course, the Behmor would be even better with the added benefit of actually being rated for AU power supply.
  • chronofields
    Originally posted by 033F2239333225303833570 link=1294049376/6#6 date=1294104173
    Originally posted by 0308120F0E0F0609050C0413600 link=1294049376/4#4 date=1294100930
    What do you guys think of the "Fresh Roast Coffee Roaster SR 500" its only 169 on Amazon... and seems to have good reviews too...
    Its a tarted up popper for 10 times the price.
    Well... :P 99% of poppers dont have a way to capture chaff (the west bend poppery II does though) also this has alot of nice features such as temp, fan control etc. But yea... Might go for the Behmor when the next paycheck rolls on in
  • chronofields
    Originally posted by 2D32302A33263130275F0 link=1294049376/5#5 date=1294102848
    Firstly, its 110V 60Hz, so youll have to convert it, and seeing as it will be running at (most likely) around 2kW, finding a 110V to 230V 2kW converter transformer will not be fun. Secondly, you may have issues with the 60Hz vs 50Hz if there are any motors in it.
    Thirdly, if it does work, then you have no warranty, which is risky on something so small that heats up to 250 degrees.
    Fourthly, Amazon wont ship it to Australia.
    So even if it is the best coffee roaster in the world, I wouldnt think about getting it.
    Well... strangely enough o.o amazon has started shipping some items to Australia... Recently i bought a Kershaw Skyline knife from them for camping use at an absolute _bargain_ (AUD29+9). But yea i agree with you, :/\/ getting that converter would be a pain and considering what price that converters go for here... XD May as well get the behmor
  • rmoulynox
    Originally posted by 646F75686968616E626B6374070 link=1294049376/4#4 date=1294100930
  • chronofields
    Originally posted by 737F767B7B721E0 link=1294049376/2#2 date=1294052924
    k mart $12 job will get you started.....
    many have breville crazy poppers that have gone for years....
    http://coffeesnobs.com.au/YaBB.pl?num=1291530048
    Hmm... Thanks Ill give that a try...
  • phrostyboi
    ive had 1 kmart 25 buck job and 2 aldi 20 buck ones - both identical except the branding
    theyre currently in storage due to the behmor
  • maheel
